Old 04-24-2018, 09:34 AM
BeaterofAincrad BeaterofAincrad is offline
2018 Build-Off Contestant
Default Air filter size for Tecumseh 6.5hp
I read somewhere on here that a larger air filter is better but Iím not sure how large is too large. So if anyone has any recommendations thatíd be great.
Old 04-25-2018, 12:56 PM
Kaptain Krunch's Avatar
Kaptain Krunch Kaptain Krunch is offline
Pro Junk Collector
Too big wont hurt anything, just looks stupid. Bigger air filter will only help as a supporting modification (exhaust, jetting, porting, valve work etc). will generally have zero effect on a stock engine.
"If you want, I can teach you how to make a bomb out of a toilet paper roll and a stick of dynamite"
The Following User Says Thank You to Kaptain Krunch For This Useful Post:
Nosandwich (04-25-2018)
Old 04-25-2018, 02:04 PM
Thx, does anybody know of a cheapish air filter that has the foam over it? Iíve heard they are better for performance and figured Iíd get a good one since I donít have one atm.
Old 04-25-2018, 03:15 PM
Pro Junk Collector
Check out Uni pod filters, they have them on ebay, amazon etc. many sizes, clamp on relatively cheap. you will need to make/buy an adapter to use one with your tecumseh though.
The Following 2 Users Say Thank You to Kaptain Krunch For This Useful Post:
BeaterofAincrad (04-25-2018), Nosandwich (04-25-2018)
Old 04-25-2018, 05:37 PM
Thanks
Old 04-26-2018, 01:26 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
http://www.bmikarts.com/Air-Filter-A...QaArIIEALw_wcB
http://www.bmikarts.com/Angled-Fabri...all_p_455.html
With Foam PRe-Filter
https://www.ebay.com/itm/CLONE-GX200...sAAOSws65TparL
but it says the adapter is out of stock. Does the engine have the long bent manifold like I had on my Teckasheema 5.0?
Or
https://www.robertsonstorquetubes.co...r-adapter-tafa
with
https://www.ebay.com/itm/32MM-AIR-FI...-/190883639181
or any of these.
https://www.ebay.com/sch/i.html?_pro...=true&_fosrp=1
https://www.ebay.com/itm/S-B-USA-Rou...ss!60803!US!-1
https://www.walmart.com/ip/Air-Filte...&wl13=&veh=sem
One adapter uses a 1.25" filter (32mm)
One adapter uses a 2 7/16" filter (62mm)
Check the bolt spacing you need to verify those adapters will fit.
Search Air Pod, Or Air Filter, .... and type in what ever size you need.
The Following User Says Thank You to bob58o For This Useful Post:
Randy H (04-26-2018)
Old 04-26-2018, 01:32 PM
KartFab's Avatar
KartFab KartFab is offline
just get the $20 ebay special: PZ22 carburetor 22mm. bolts right up and has an air filter. Use air filter oil on the air filter and you will be fine.
The Following 2 Users Say Thank You to KartFab For This Useful Post:
bob58o (04-26-2018), Randy H (04-26-2018)
Old 04-26-2018, 01:41 PM
The bent thing between the carb and the motor? Yes.
At first I was going to get a 52mm filter and then machine an adapter if I had time. First comes the swing arm then the adapter or something. I mean I can always buy an adapter.
Thanks for all the suggestions.
---------- Post added at 02:41 PM ---------- Previous post was at 02:34 PM ----------
I saw that in another post and was considering it. I ran into a problem though, I had an extra motor cycle brake cable from another project and had to put that on for the throttle.
So Iíd probably have to get a new cable too.
I was thinking about getting the HS40 carburetor.
Old 04-26-2018, 01:45 PM
bob58o's Avatar
The PZ22 is a direct bolt-on replacement for the Tec OHV stuff? It bolts onto the manifold?
I had no idea.
