Old 10-25-2019, 08:46 AM
Budget GoKart's Avatar
Aka a kenbar
Default Does a vertical shaft 5hp block work with horizontal 5hp parts?
I have a 5hp briggs with a bad block if I got an old lawn mower and ripped it apart for its block will it work it would have to be a briggs 5hp though. And what I mean is if my internals would fit in the other block. And I would be able to use my crank and side cover?
---------- Post added at 07:46 AM ---------- Previous post was at 07:43 AM ----------
Never mind I took a good hard look at one and it doesn't have the same engine mount also briggs blocks are 20$ on ebay
