Old 03-13-2019, 11:05 PM
kwf2020 kwf2020 is offline
Default Predator 212
Hi everyone. I just put a new non-hemi Predator 212 on my kids cart. He wants lights on it, so I'm thinking about doing the coil and flywheel swap so it can power lights. My question is, what is the voltage and current that's provided by the coil?
Old 03-14-2019, 12:17 AM
Ebrownie's Avatar
Ebrownie Ebrownie is offline
The general consensus is that it’s not worth the time or money needed to put a charging coil on a predator. It can certainly be done, but many of us, including me, have simply put little SLA 12v batteries on our karts/bikes to power lights. Every few hours of run time, you just recharge the battery.
It is easy, cheap, and with LEDs, you can get a lot of run time out of a charge. I have 2 18W pods and a taillight/brakelight on mine, so it probably draws somewhere around 4 amps. I have a 12 amp/hour battery, so theoretically I can get 3 hours of lights, which is plenty good for what I use it for.
1CE4485F-F5E9-4BE2-932D-84A0FAB274F5.jpg   EF0D61FC-1314-42C7-84E0-3287E4D7B600.jpg
The Following User Says Thank You to Ebrownie For This Useful Post:
Panhead5496 (03-14-2019)
Old 03-14-2019, 01:06 PM
Tpdingo Tpdingo is offline
Also could dump the predator and get a tilletson motor that comes preinstalled with e-start and coils.
Kartorbust (03-14-2019)
Old 03-14-2019, 03:37 PM
txluke txluke is offline
I think battery and led's are the way to go.
