Reply
Old 02-23-2020, 01:05 PM
VASwinger VASwinger is offline
Junior Member
Default Questions about Clutch/TC Operation
Howdy everyone! I have some questions about clutches and TCs.
I currently have a 30 series drive clutch on a 212 Predator. I purchased an inductive tachometer to get a better idea on exactly what rpms things were happening-
It is not on a go kart- itís actually a kids ATV with same clutching as go karts (ETON Viper 90)
Idle rpm between 1600-1800. Idles a bit higher when cold
Clutch engagement/lockup between 2800-3000 rpm
Wide open throttle - 3600-3750 rpm
Engine is stock.
My problem is the 3000 rpm engagement speed. How do I lower this?
Will a 40 series TC solve my issues.
Old 02-23-2020, 10:46 PM
Brianator Brianator is offline
Heres the chart for the garter springs and weights to fine tune your engagement rpms. 2300ish rpm is stock for the 30 series and that's achieved with "blue" springs and zinc weights. Garter springs are pretty cheap and easy to order online (and install) so I'd recommend getting a couple different ones that will lower the engagement rpm and experiment.
"Put off until tomorrow what you can do today!"
Old 02-23-2020, 11:15 PM
itsid's Avatar
itsid itsid is offline
blue and zinc is the stock configuration of a series30
(and also all chinese copies)
While chinese copies can vary a bit more than proper Comet parts
full lock past 2800 is indeed odd.
But usually chinese TCs aren't that bad tbh..
so the springs should be close enough to comet's specs
maybe it's indeed just tiny misalignments and issues that add up
and we can solve that without buying anything..
for that pictures will be needed.
Are you sure the clutch is properly mounted and so is the belt?
could you provide a few pics please?
does it feel sticky perhaps?
if so you maybe forgot to lube the driver weights
(dry lube ONLY!!)
late engagement can also be a cause of bad gearing btw...
so maybe tell us about your chain ratio as well.
if that fails I'd buy and try both,
original comet blue and pink carter springs (beltpalace has them all AFAIK)
but the stupidly high idle of a predator can cause an issue with the pink ones already.
but it's still cheaper than buying a better quality engine (the Honda gx200 idles at 1200 rpms)
Old 02-25-2020, 11:32 AM
Junior Member
Thanks.
I’ll update with some pics.
Reply
