Old 06-09-2019, 09:34 PM
5814SpeedCo 5814SpeedCo is offline
Default Manco buggy
Lots of mock up and planning happening before I get to setting up this Dingo. Went from 4" of ground clearance to about 13", got rid of the roll cage except the main hoop and will be fabricating a new one. I'll have to fabricate the ATV suspension front end. Setting up the rear for dual shocks as well.
Motor will be a Predator 212 for now but will eventually upgrade later.
Old 06-09-2019, 10:21 PM
Budget GoKart's Avatar
Aka a kenbar
Why?
Old 06-10-2019, 02:01 AM
landuse's Avatar
landuse landuse is online now
Looking good. I have a feeling you are going to be dissapointed using the 212 though
Originally Posted by Budget GoKart View Post
Why?
Why what?
Old 06-10-2019, 06:45 AM
Why?
Simply put.... because I can.
I do have an SV650 motor at my disposal, has everything except the radiator and ECM. I may just do that motor and have a quick little beast!
Old 06-23-2019, 05:35 PM
One seater to two seater coming up. Can't afford a new kart so making this one into one I can take my wife and daughter around in. Got tubing and frame slugs and then will complete the front end and start building the cage.
Seat is a JEGS pro high back 2, have to get one more and then cut a couple of tubes out to start mounting the seat. Will pretty much build the kart front the seats outward
The Following User Says Thank You to 5814SpeedCo For This Useful Post:
landuse (06-24-2019)
Old 06-30-2019, 07:02 PM
Started on the front end today
Old 06-30-2019, 09:57 PM
Aka a kenbar
It pretty awesome but sad because you used almost none of the manco
Old 07-03-2019, 10:50 AM
More front end work
Old 07-04-2019, 02:07 PM
Connecting the main frame to the front end. Happy 4th of July everyone!!!!
JTSpeedDemon (07-04-2019)
Old 07-06-2019, 01:13 PM
Hope to have her sitting on her own two feet in the next few days. Thought I ordered tabs for the upper shock mounts, but I'm living it so far!!
My jig has been very handy so far, along with my degree dial gauge and trusty level. Got to keep it square and even!
  #11
Old 08-04-2019, 06:20 PM
Slow progress! Rethinking the front end a little bit now.
  #12
Old 08-11-2019, 01:11 AM
Smerft85 Smerft85 is online now
I agree, I would have started from scratch, built the dingo and had two! What do you have as for spare dingo parts around? A couple of us may be interested in buying what you don't need...
  #13
Old 08-11-2019, 06:39 AM
Aka a kenbar
If you have all of the little peice weld together what you have and then recreate the rear bit and boom two karts
  #14
Old 10-17-2019, 06:07 PM
Front end is finally sitting on the ground by itself. I designed the plates note only be shock towers but also aid in bracing the front end some.
Texan (10-18-2019)
