Old 07-23-2019, 12:52 PM
Myloram Myloram is offline
Default New to karting
Afternoon,
I am goking to build a kart for my clones and putting a parts list together now. I have noticed some talk about the several of the engines like the DuroMax XP18HPE and the Predator 212. The cart will be used by the family (me @195, my 14yo @155, and 2 littles @ 50-60 lbs). Use will be mix on and off road. Tire change will be done for use. I can't leave anything stock for long for SA. I'm pretty good with a welder hence me fabbing the kart. I'm open to suggestions and questions. Pic of the design is attached.
Eric
Old 07-23-2019, 02:47 PM
BigWes's Avatar
BigWes BigWes is offline
Uh oh... copyright violation already!
18 hp might be a bit much, what does the plans for the kart call for? How much does it weight? A 212 will carry any of you around just fine...but how big and heavy is your machine...that is the question!
Old 07-23-2019, 05:41 PM
Bansil's Avatar
Bansil Bansil is offline
Originally Posted by Myloram View Post
Afternoon,
Eric
Exactly how many of you do you have
Old 07-24-2019, 01:03 AM
landuse's Avatar
landuse landuse is offline
I would also say 18hp is a bit much. A 212 with some performance parts should be fine
Old 07-24-2019, 06:54 AM
I bought the plans. I may just do a build blog and see how it goes. I have 4 sons that I'm aware of. Not sure on the weight to be honest. It's 80' of 1x1.25 14 gauge for most of it.
Eric
Old 07-24-2019, 07:13 AM
bthompson224's Avatar
bthompson224 bthompson224 is offline
A quick glance at HD website, 72" weighs 32 lbs. 80 feet is over 400 lbs for the frame alone. And that's 16ga. You sure about that 80' number?
Old 07-24-2019, 09:19 AM
Bansil's Avatar
well according to my ryerson/alro books 1-1/2 x 1 x .083 is 1.317 lb per foot (no mention of 1-1/4 x 1) so less than 106 lbs
Old 07-24-2019, 09:46 AM
I am basing the 80' on the build sheet, but 40' is 1x1 box. so not a big change in weight. Ill also have a some 16g sheet for flooring and shielding without modifications.
Eric
Old 07-24-2019, 12:40 PM
KartFab's Avatar
KartFab KartFab is offline
hands down, predator 212 will give you the best bang for your buck. change my mind.
The Following 2 Users Say Thank You to KartFab For This Useful Post:
Hellion (07-27-2019), Kartorbust (07-24-2019)
Old 07-25-2019, 07:20 AM
What are the thoughts on the 212cc Tillotson Hemi Engine with upgrades down the road?
Eric
  #11
Old 07-25-2019, 12:22 PM
Kartorbust's Avatar
Well the benefit of a Tillotson was you can get it with electric start, something the 212 Predator doesn't offer. Supposedly the flywheel on the Tillotson is rated for 10,000 RPM (at least on the non-electric start far as I'm aware). Cams and the like should be mostly interchangeable. The 212 Predator seems to be the most bang for the buck. Unless electric start is a must have.
  #12
Old 07-30-2019, 07:31 AM
For dual engine karts, do you have to use 2 reverse kits or can you get by with just 1?
  #13
Old 07-30-2019, 08:52 AM
landuse's Avatar
AFAIK you would have to use 2. Trying to have a seperate throttle just for the one engine that has the reverse will be a pain.
  #14
Old 08-05-2019, 09:43 AM
Picked up some parts to start the build with. Now to get my metal and make a new frame.
Mylo
  #15
Old 08-06-2019, 08:02 AM
Bansil's Avatar
Good to see this moving forward
