Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
  #21
Old 07-31-2019, 10:00 AM
Smerft85 Smerft85 is online now
Man, if you were closer I'd help you rebuild that front end, wouldn't be perfect, but new metal for sure!
The Following User Says Thank You to Smerft85 For This Useful Post:
Dingocat (07-31-2019)
  #22
Old 07-31-2019, 01:54 PM
What if you took a piece of pipe cut horizontally in half and placed it on the pitted portion on the bottom and weld it in? That should provide more than enough strength assuming the top isn’t pitted like the bottom.
  #23
Old 07-31-2019, 04:35 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
The OP does not have the tooling to do any metal work.
  #24
Old 07-31-2019, 10:17 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
Quote:
I don't have pipe/tube but if I did I'd weld on the piece. have the tools to cut, grind, weld, sand, but not bend.
If it's not scary you're not going fast enough
  #25
Old 08-03-2019, 10:20 PM
Dingocat's Avatar
Broke
Update, or rather lack of. Dingo frame is sitting, half primed. I ran out of primer. And I broke my only running kart today. Back sheave of driver broke off of its hub. I don't know how or why but will see of we can weld it back together.
  #26
Old 08-07-2019, 10:51 PM
JohnnyRingo's Avatar
JohnnyRingo JohnnyRingo is offline
Junior Member
Look forward to seeing the end result, DC!!
The Following User Says Thank You to JohnnyRingo For This Useful Post:
Dingocat (08-08-2019)
  #27
Old 08-08-2019, 05:28 PM
Dingocat's Avatar
Broke
Newest find. Needs carb/tank clean and some paint.
  #28
Old 08-08-2019, 06:24 PM
What is it? Snowblower engine?
  #29
Old 08-08-2019, 07:14 PM
Dingocat's Avatar
Broke
Quote:
Whole thing. Missing airbox/carb cover. Has updraft carb. And crosshatch.
  #30
Old 08-08-2019, 10:25 PM
So the question becomes...what are you going to do with it?
  #31
Old 08-08-2019, 11:26 PM
Yes, what are you going to do with it? Are you starting to hoard cheap engines too?
  #32
Old 08-08-2019, 11:35 PM
Junior Member
Quote:
I hate it when that happens. Seriously. The time the other day when I found that dull penny I forgot to mention, I was wondering where the other $999,999.99 wubbs.
  #33
Old 08-09-2019, 07:36 AM
Dingocat's Avatar
Broke
Brutal! And we already hoard engines too. Here's pics of the whole thing. Should be able to get 300-400 depending on how good I clean it up.
  #34
Old 08-09-2019, 08:11 AM
Can't give a snow blower away around here, never enough snow.
  #35
Old 08-09-2019, 09:17 AM
Dingocat's Avatar
Broke
Quote:
I'm in northeast ohio so we get lake effect snow. Not fun when you want to go somewhere.
  #36
Old 08-09-2019, 11:08 AM
Junior Member
Nice old motor there! You going to fully restore it, paint and all?
  #37
Old 08-09-2019, 01:44 PM
Dingocat's Avatar
Broke
After a little while. I still have to do the dingo first though. So this gets to sit on the backburner for a bit.
  #38
Old 08-10-2019, 09:00 PM
Did you ever get more primer for your dingo?
  #39
Old 08-10-2019, 09:32 PM
Dingocat's Avatar
Broke
Nope. NONE at ace. So my dad's going to pick some up from walmart on his way home from work on monday.
  #40
Old 08-10-2019, 11:42 PM
I didn't bother with primer, but learned a few tricks when I did paint and body. After paint it goes together super fast, and I did figure out the throttle pedal at least, so If you need pictures when you put it together I can post some.
Reply
