Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
  #21
Old 10-16-2018, 01:50 PM
Stephen115 Stephen115 is offline
Quote:
Originally Posted by Tpdingo View Post
Well depends on how fast you are going. Those brakes are usually much more powerful than the tires grip. If you just want pure bloody fast acceleration with a low gear ratio and incredibly sticky tires, the stock brakes should stop no problem. Consider hydraulic brake kit too. Just remember you are limited by your tire's grip, not your brake limit. Also note that when you are going 40-60mph and you try to stop, you can get those brake calipers to put out a lot of stopping power with a little something called ADRENALINE. It's power brakes for your go kart
The goal is to eventually go pretty fast, maybe see 70mph. We need to work out all the kinks before we get there.
I hear you, I just don't have a lot of faith in the drum and band brake setup.
Thank you!
  #22
Old 10-16-2018, 03:39 PM
Tpdingo Tpdingo is offline
Oh its a band brake? No no no that will never stop you. You gotta go to mechanical disc brakes. I'd say maybe go to hydraulic but that would be easily 300$ vs maybe 50$ for mechanical and the kart is maybe 250 so it should be fine. Its not like a two seater Manco Deuce where its like 6-700 lbs without people.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
The Following User Says Thank You to Tpdingo For This Useful Post:
Stephen115 (10-16-2018)
  #23
Old 10-16-2018, 07:40 PM
That's what I was thinking. I'd like to find a motorcycle rear caliper and master cylinder if I can. It would probably be more than we need. I'll see what I can find. Thank you!
Sent from my SM-N960U using Tapatalk
  #24
Old 10-17-2018, 08:52 PM
Thoughts on this setup?
https://www.gopowersports.com/go-kar...xoCjDIQAvD_BwE
  #25
Old 10-17-2018, 09:38 PM
That's the one I use on my Manco Dingo and it locks those back tires up like it's no one's business. And it is set on the highest mechanical advantage(easiest to push, little braking power). Set that puppy up for ADRENALINE MASHING COCAINE SMASHING BRAKING POWER and your *** will be dragged to a halt in no time.
(Though in super hard mode, work your ankle muscles, you'll need them, also figure out if you need all the power and if a weaker mode would work. If need be, you could make a handbrake and use the mechanical advantage of your arm instead your ankle.)
Have fun setting it up
(It's very easy for adjustment, just make sure to check it regularly as there is no automatic adjustment.)
I think cars and cameras uses that on most of their projects, I don't remember them using hydraulics on the mower and that thing slowed down from 65mph w/ no issue so my guess is "IT'L BE FINE"
  #26
Old 10-18-2018, 11:18 AM
I appreciate the help!
I called Go Power Sports to ask them about the brake kit, and explained what I was building. He said they built something similar a number of years ago with a 20hp v-twin and the mechanical brakes didn't do it justice. They ended up going with trailer brakes at the time. He suggested I look into hydraulic brakes. He also said that he's never heard of anyone putting one of these on a go kart. Could we be the first ones? I find it hard to believe.
  #27
Old 10-18-2018, 12:13 PM
PullHorse PullHorse is online now
I've recently replaced that same mechanical brake with the hydraulic disk brake below. The stopping power between the 2 isn't really on the same playing field. You have front brakes so perhaps mechanical will do but that sure is alot of power you have on there.
https://www.gopowersports.com/80t-mi...-kit-6-000-000
  #28
Old 10-18-2018, 03:33 PM
What would be wrong with buying a used rear caliper and master cylinder off of a motorcycle? There are a lot of used sets on ebay. We can make the rotor, and brackets.
  #29
Old 10-18-2018, 05:19 PM
Nothing at all!
  #30
Old 10-19-2018, 11:07 AM
65ShelbyClone's Avatar
65ShelbyClone 65ShelbyClone is offline
I agree. If you get the right master cylinder, the caliper doesn't even have to be a rear one.
I'll show those guys who's in top place, I'll really give 'em a hotrod race.
  #31
Old 10-19-2018, 01:09 PM
I found a rear brake set off of a 2010 Honda CBR600RR with master cylinder & caliper for $25 + FS!
We'll start here, we can always upgrade.
  #32
Old 10-20-2018, 01:49 PM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
What I see is you want to go fast and do it cheaply. Very doable. Remain alive.....not so much.
I do not recall Congressman.
The Following User Says Thank You to Nosandwich For This Useful Post:
Stephen115 (10-20-2018)
  #33
Old 10-22-2018, 07:54 PM
Our "cheap" brake setup came in today. Everything is here, and seems to be in good working order!
Just need to find a new rotor and machine the hub.
The Following User Says Thank You to Stephen115 For This Useful Post:
landuse (10-23-2018)
  #34
Old 10-23-2018, 08:59 AM
karte_m0lim's Avatar
karte_m0lim karte_m0lim is offline
Rotor you mean disc?
In all my projects i used motorcycle / scooter brakes ( master cylinder, callipers and disc...
But looking forward to see your kart on the road
YouTube: https://www.youtube.com/user/kartem0lim/videos?
  #35
Old 10-23-2018, 09:59 AM
I feel like disc and rotor are one in the same, but yes a disc.
Thanks for the input.
  #36
Old 10-23-2018, 11:22 AM
A disc usually is in reference to karts and motorcycles. Rotors are usually for cars but yes they are the same thing.
  #37
Old 11-01-2018, 08:04 PM
Installed new clutch springs and shoes. We also made an adapter. Originally it would of had something similar, but since you can't find a lot of parts for this clutch we had to make it. The only thing we need now is a thrust bearing.
landuse (11-01-2018)
  #38
Old 11-01-2018, 08:19 PM
rushking19's Avatar
rushking19 rushking19 is offline
Nice build Iove it and If that thing has 34 hp I wonder how torque it has
It's Fast ,But Needs One More Cylinder
  #39
Old 11-04-2018, 12:53 PM
Quote:
Thank you! I believe it's around 50 ft-lbs
  #40
Old 11-05-2018, 07:04 AM
S S S S is offline
idiot who has little clue
something tells me that may be a bit much in the power department.
Reply
