  #21
Old 06-20-2019, 09:05 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Could it be 1/4-20?
That's the size on a 5 HP Briggs and a 4 HP Tecumseh I just checked (flatheads).
  #22
Old 06-21-2019, 02:33 PM
Bansil's Avatar
Bansil Bansil is offline
If you can after center punching the bolt, use a left hand drill bit, it may just unscrew itself
---------- Post added at 02:33 PM ---------- Previous post was at 02:30 PM ----------
If it is 1/4-20, a .201 is tap drill size, so use a .1875 (3/16) drill bit so you don't mess up threads.
  #23
Old 06-24-2019, 09:27 AM
Holmes's Avatar
Holmes Holmes is offline
It was 1/4-20. I was able to chase the RH hole and get the muffler mounted. The LH one; I punched and drilled it out and tried the easy-out with blaster but it was seized too tight. I sprayed some additional blaster on it and tried again; no luck as of yet.
I got the motor to start and run now with the muffler on with a single bolt; but it dies under loading again so I'm guessing another carb cleaning is in my near future. Seems like I have to take the thing apart and clean the jets every 2-3 hours of use. Seems excessive to me?
