Closed Thread
Old 10-19-2010, 03:53 PM
kadsjr's Avatar
kadsjr kadsjr is offline
The Kart Expert.com
Default Whats this Called?
does anyone know what this mod of the engine air filter is called?
jr dragster T's Avatar
jr dragster T jr dragster T is offline
That would be known as a 15* angled K&N style air filter. Its not really part of the engine, Its a aftermarket thing. You should research a little bit about motors first before you attempt to modify anything.
Old 10-19-2010, 03:55 PM
kadsjr's Avatar
The Kart Expert.com
thanks but is that all i need to but to fix it onto my clone isnt there more things to attach to it? i did know it was a air filter but i didnt know the name of it spasificly can anyone help me on how to fix it on to my suntom clone?
Old 10-20-2010, 12:22 AM
bighead's Avatar
bighead bighead is offline
Quote:
Originally Posted by jr dragster Tyler View Post
Well yes, Your going to need a air filter adapter of course. It usually comes in a kit with a header, filter adapter, filter and a larger main jet. Here is a excellant kit here.
http://www.affordablegokarts.com/mm5...gory_Code=BOK1
I made my own air filter adapter from the stock air filter on my HF Clone.
I took a hack saw and starting cutting. I was able to make a nice little adapter to hold the air filter on. The hole is not perfect round but with a clap it hold a small filter on with no problems. Then all you need is a cheap filter with a 2" end.
You will need to make a little bracket to hold your chook lever down. Notice the little tab coming off the starter cover? Just use a sheet metal screw and the little tab.
Here some pics.
I am going to make a thread about this mod. Maybe other can use it.
The Following User Says Thank You to bighead For This Useful Post:
kadsjr (10-20-2010)
Old 10-20-2010, 02:25 AM
kadsjr's Avatar
The Kart Expert.com
looks great gonna try it on my old 4hp! i also dont know where i could find a place where does exhausts without a muffler on it where they send it to england or is in GBP ? could any one help?
Old 10-20-2010, 02:30 AM
bighead's Avatar
Quote:
Just cut off your old muffler and use that exhust flange. Then find a pipe and weld it to your original flange. All you need is a pipe and a weld.
Thats all I did in the pics above. That short pipe you see hass baffles in it. So not really a strait pipe.
  #7
Old 10-20-2010, 06:36 AM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
I would advise against cutting off the muffler, just in case you ever want to use th muffler again. Get a piece of 1/8 inch steel and make a new flange.
ASE Certified
Closed Thread
