Go Back   DIY Go Kart Forum > Building Plans And Advice > Using Tools and Welding
Closed Thread
Old 07-30-2010, 09:22 PM
NewLife2626 NewLife2626 is offline
Junior Member
Default 110v arc welders
Needing a welder for my buggy project but only have access to standard 110v, and me being a big guy I am thinking I need to use bigger tubing so from what I understand is that an arc welder is going to give me more power to melt bigger rods than using a 110v mig with smaller wire, please correct me if I'am wrong please, I have arc and mig welded before and wasn't bad at either so I'am open to suggestions.
Old 07-30-2010, 10:30 PM
Kenny_McCormic Kenny_McCormic is offline
Kartless....
If you only have 110 to work with, fluxcore wire welder is the only answer.
Old 07-30-2010, 10:50 PM
redsox985's Avatar
redsox985 redsox985 is offline
I believe I've seen sticks for 110v but mig/FC is much easier to do. Especially if you have to do inverted/ strange angle welding.
Old 07-31-2010, 04:36 AM
modelengineer modelengineer is offline
Lord of the noise
If you use larger diameter tubing, rather than thicker wall, you won't have any problem with the welding. Also, the larger diameter tubing is stronger - per weight - than smaller diameter thicker tubing.
Andrew
GS500F powered...
Old 08-02-2010, 11:23 PM
DirtTrackRacer_07's Avatar
DirtTrackRacer_07 DirtTrackRacer_07 is offline
DeeR SlayeR
Flux core wire feed all the way.
110 volt stick are ok but i personally dont like the way they weld.
I think you also have to buy them tiny welding rods that cost more.
Old 08-12-2010, 10:08 PM
motor_head's Avatar
motor_head motor_head is offline
expert garbage picker
you could just run a 220 line to your garage or where ever your working at,
it's not very hard to do
  #7
Old 08-12-2010, 10:15 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Its really not, but we dont want someone who may not have any experience with electrical work running a 220 line.
ASE Certified
  #8
Old 08-13-2010, 01:31 AM
acg23's Avatar
acg23 acg23 is offline
get the 220 and everytime you wanna weld just unplug ur washer and plug in ur welder.
DO A BARREL ROLL!!!
  #9
Old 08-15-2010, 10:17 PM
jr dragster T's Avatar
jr dragster T jr dragster T is offline
Quote:
You mean Drier?
  #10
Old 08-15-2010, 11:01 PM
devino246's Avatar
Quote:
Originally Posted by jr dragster Tyler View Post
You mean Drier?
Ya, who has a 220V washer? acg23, the only problem with that is some houses have the laundry room upstairs or in the basement.
ASE Certified
  #11
Old 08-16-2010, 01:15 AM
acg23's Avatar
yea.. hada few beers befor that post. but you knw what i ment.
DO A BARREL ROLL!!!
Closed Thread
