Go Back   DIY Go Kart Forum > Building Plans And Advice > Electric Projects
Reply
Old 07-21-2019, 12:50 PM
Tony86 Tony86 is offline
Junior Member
Default 48v1000w go kart upgrade to 48v1800w
Hi all I have converted a 48v 1000w to a 48v1800 I have it working but forward is reverse and reverse is forward I have some pictures if it helps ino its hard to see but if somebody noes why it does this would be a great help thankyou tony
Old 07-21-2019, 12:56 PM
itsid's Avatar
itsid itsid is offline
NO HIJACKING!!
On a brushless motor, just swap any two phase wires (and if you have their respective sensor wires)
say yellow and blue ..
Tony86 (07-22-2019)
Old 07-21-2019, 05:13 PM
Junior Member
Hi Sid thanks for the reply I tried swapping most the wires and all I get is the same result backwards bein forwards I have a drive switch which connects to the forward and reverse switch but do not have enough wires and really don't no how to wire ,it ino it must be a simple switch over but Don't no what ? ��
Old 07-21-2019, 06:05 PM
Functional Artist's Avatar
Functional Artist Functional Artist is offline
IIRC
To reverse the direction of these brushless motors
...connect the thick blue motor wire to thick green controller wire
& the thick green motor wire to thick blue controller wire
...keep thick yellow motor wire connected to the thick yellow controller wire
Then, on the 5 wire plug (thin wires) swap the blue & yellow wires
RESISTANCE IS FUTILE
The Following 2 Users Say Thank You to Functional Artist For This Useful Post:
Bmr4Karts (08-06-2019), Tony86 (07-22-2019)
Old 07-22-2019, 04:49 AM
Junior Member
Thankyou ever so much functional artist it is going forwards I have one other small problem I want to be able to connect the forward and reverse switch to the computer/motor/ can i do so with this wiring (check pictures) or do i have to buy a new switch that will go into inverted gear as at the min the are bypassed black to yellow to go forward , but the wires on the connector are far to skinny to go to the big switch which has fat wires green and blue and black and red ?? Pictures have been uploaded many thanks
Old 07-22-2019, 05:22 PM
This thread may be of assistance
http://www.diygokarts.com/vb/showthread.php?t=37537
The Following User Says Thank You to Functional Artist For This Useful Post:
Tony86 (08-04-2019)
  #7
Old 08-04-2019, 04:40 AM
Junior Member
Functional artist after everything working put it all together its not working? Have I blown the motor ? Controller? the wheels were struggling to spin properly if you twisted them it would help them move a bit but not properly.. and the wheels dont spin now lost all power to the motor I think green and blue wires and yellow have any volts going to them but not sure ? Any1 have any simple test methods? Or anything would be so helpful as I've had it working... now it dont spent so many hours an neally bout to buy the motor controller again ( help ��
  #8
Old 08-04-2019, 07:11 AM
Sounds like you may have mixed something up during re-assembly
...I've done it before
As long as you didn't let the "magical smoke" out
...there's still hope
Go thru the whole system, in your head/on paper
...then, go to the kart & double everything
Tony86 (08-09-2019)
  #9
Old 08-04-2019, 08:53 AM
itsid's Avatar
Wait..
you DID swap the controller too, right? not just the motor..
otherwise you likely burned your controller by now
Tony86 (08-09-2019)
  #10
Old 08-09-2019, 07:09 AM
Junior Member
Functional artist I have thats why I'm still so puzzled by it treble checked it and you helped me make it go forward and I have that in writing i feel like there's no way I have gone rong haha unless computer or motor died.... I have a multi meter? Is there checks on there I can check with computer ? Or is there a straight feed to the motor to the batt I can do to check its working ? I have the indicator light on kart coming on so I think computer may be still alive ?
Reply
