Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
  #81
Old 05-13-2019, 08:46 PM
itsid's Avatar
itsid itsid is online now
Stock rod over revved..
the reason why we ask to install billet con rods as soon as you rev more than the stock valve springs allow for
Too bad!
  #82
Old 05-14-2019, 04:20 AM
chados chados is offline
Yes, the standard connecting rod wedged at the bottom, and broke. I installed an intake valve 27mm camshaft with an increased lift of 1mm. Raising the power connecting rod could not resist. Need to put the rod ARC.
EB5839F2-F9E0-4E76-B3E5-8C71C44539A6.jpg   DCE50CDD-D497-42CC-B4CC-DD26439E5BC7.jpg
3C4BB24B-B5E1-430A-8B54-45231848BAF6.jpg   412DC6AE-2F35-4D71-8B6F-5854A648447C.jpg
  #83
Old 05-14-2019, 07:46 AM
J.S.@SMS's Avatar
J.S.@SMS J.S.@SMS is offline
Road Hazard
That sucks, but it could have been worse (rod hitting you on the way out). At least you weren't injured. But the block is done. The rod took out part of the cylinder and cracked the sleeve, from what I can see. And the crank looks pretty bad.
For his personal safety, keep this one away from bicycles.
  #84
Old 05-24-2019, 07:40 AM
I recently ordered the ARC 6270 and aluminum valve rods (OEM honda gx200 ut2).
  #85
Old 07-20-2019, 03:56 AM
please tell me what oil viscosity should be used for ARC Rod 6270 Honda/Clone?
  #86
Old 07-20-2019, 03:17 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
If it's not in the manual for the rod, then use what the manufacturer recommends for the engine.
The Following User Says Thank You to Kartorbust For This Useful Post:
chados (07-21-2019)
  #87
Old 07-21-2019, 12:58 AM
Quote:
The instructions recommend a medium weight oil, which is a 30w with a high zinc content.
My motor is used in races at speeds above 7000 RPM. I think we need oil with a viscosity of 10w30. Redline, Amsoil or Valvoline?
  #88
Old 07-21-2019, 11:33 AM
Kartorbust's Avatar
10w30 should be fine. In the summer time, it still acts as a 30 weight. In the winter it's a 10 weight. Should be fine.
chados (07-28-2019)
  #89
Old 07-28-2019, 09:11 PM
Good afternoon members of the forum,
Please tell me whether it is reasonable to use Autolite AR3910X candle.
My compression ratio is now around 10.5: 1, the combustion chamber is 14 cc. thin steel gasket, but the piston is not flat-top.
  #90
Old 08-03-2019, 04:02 AM
Hello dear forum users, I had a question about the compression ratio of my Honda clone.
Now I have a 14cc combustion chamber
The standard piston is not a flattop.
Head gasket thin steel.
according to my calculations, the compression ratio is 10.3 - 10.5: 1
I want to install a flattop piston, but then the compression ratio will be already 13: 1, I'm afraid that this is of great importance.
Do I need to install a thick head gasket?
or will the motor withstand this compression ratio? I use the motor on karting in races, the engine speed reaches 7500 rpm.
Reply
