Go Back   DIY Go Kart Forum > Building Plans And Advice > Using Tools and Welding
Closed Thread
Old 12-13-2017, 01:39 PM
Blackdog Blackdog is offline
Default How to drill holes in mild steel: 1/2" up to 1 1/4" or so?
My standard twist drill bits go up to 3/8" I could buy a 7/16" if I needed it. What about drilling larger holes? How is that accomplished ?(presently I do not have a plasma cutter or a drill press)
Old 12-13-2017, 01:41 PM
ezcome-ezgo's Avatar
Google "step drill"
The Following 2 Users Say Thank You to ezcome-ezgo For This Useful Post:
kevbo22 (12-13-2017), Whitetrashrocker (12-13-2017)
Old 12-13-2017, 02:15 PM
Texan's Avatar
Texan Texan is offline
Senor Member
Hole Saw works too, depends on what thickness you are drilling thru.
Old 12-13-2017, 03:37 PM
Quote:
Like a diamond-dust bit?
Old 12-13-2017, 03:41 PM
This is the answer:
https://www.amazon.com/dp/B06Y25PFMZ...a-308479138730
The Following User Says Thank You to ezcome-ezgo For This Useful Post:
andrecht (12-14-2017)
Old 12-13-2017, 04:15 PM
mckutzy mckutzy is offline
But more importantly... What is the thickness of metal you are drilling into?
  #7
Old 12-13-2017, 06:24 PM
Probably 3/16 or so....i can see that the step bit is going to be less functional as the material gets thicker
  #8
Old 12-13-2017, 06:36 PM
Kartorbust's Avatar
Kartorbust Kartorbust is online now
Are you using a drill press or hand drill? Drill press will allow better speed control because most use a step pulley jackshaft vs using high/low on a drill. A bi-metal hole saw from Lenox or Milwaukee should be fine.
Sent from my SAMSUNG-SM-G935A using Tapatalk
---------- Post added at 06:36 PM ---------- Previous post was at 06:34 PM ----------
If you buy a new hole saw, make sure it has an Arbor with it (it screws into the top of the hole saw and has a pilot drill bit in it). Doesn't add much to the cost of the bit and you can use it for similar sized hole saws in the future.
The Following User Says Thank You to Kartorbust For This Useful Post:
Nosandwich (12-14-2017)
  #9
Old 12-13-2017, 06:57 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
These are nice.
https://www.homedepot.com/p/Klein-To...1872/203499109
Think for yourself, Question authority.
  #10
Old 12-13-2017, 07:15 PM
Kartorbust's Avatar
Quote:
Originally Posted by Whitetrashrocker View Post
Oofda! That's a bit expensive, those better last longer than standard hole saws at that price.
  #11
Old 12-13-2017, 07:17 PM
OzFab's Avatar
OzFab OzFab is offline
I now have a nice set of hole saws & a drill press so, it's east but, I didn't have those back when I built AusEx; you may find this helpful
The Following User Says Thank You to OzFab For This Useful Post:
Blackdog (12-15-2017)
  #12
Old 12-13-2017, 08:10 PM
Carbide. Treat them well and they will last.
You know how some people can break an anvil.
  #13
Old 12-13-2017, 08:15 PM
Kartorbust's Avatar
Well yeah as anything else. Though some anvil are built like absolute crap. HFT ones may have body filler in them instead of being solid metal. https://www.youtube.com/watch?t=206s&v=quL14Csmi_Y
  #14
Old 12-13-2017, 08:35 PM
Lol. Glad I have an ancient one from my great grandpa. It's solid.
  #15
Old 12-13-2017, 09:03 PM
kevbo22's Avatar
kevbo22 kevbo22 is offline
The step drill bit will be way better that the bi metal hole saw.
Go with a step bit
  #16
Old 12-14-2017, 05:17 AM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
Quote:
Go with a step bit
Don't know of any step drill bits that go up to 1 1/4"????
But, I have used them on 12 ga. sheet metal, and before you break through, you're liable to be hitting that next step.
What do you do when you are hitting the next step on both sides of that 3/16" steel??? C'mon, man!
Next, drill press...well, great IF ... you're not trying to center a hole in a 22' piece of steel. ( Not likely, but , with such minimal imput, assume nothing, right?)
Whether it's 14 gauge or 3/16" , a Millwalkee metal hole saw will do it. ( Pretty cheap at HD.) The key is to go slow, use lubrication, and clean up the chips as you go.
OOPS!! Just saw Easy posted a unibit that goes up to 1 3/8". ( Still don't see how that works on 3/8"steel?)
I do not recall Congressman.
  #17
Old 12-14-2017, 08:23 AM
supermanotorious's Avatar
supermanotorious supermanotorious is offline
Winchmaster 5000
Well I've gotten to the point where if I drill more than a couple holes of a size that I have to use the step bit, I just go to the hardware store and buy the individual bit. I've done that with 5/8" 11/16", 3/4" 10mm
www.phoenixwinch.com
www.facebook.com/wakeskatewinches www.youtube.com/user/phoenixwinch
The Following User Says Thank You to supermanotorious For This Useful Post:
  #18
Old 12-14-2017, 08:31 AM
I don't have a lathe, have purchased a step drill bit with a max diameter 1" to bore out a bushing to accept a 1" shaft. It was hairy, but it worked.
  #19
Old 12-14-2017, 09:03 AM
Nosandwich's Avatar
The REAL Poboy
Quote:
The key word here being max . And this is apples and oranges in a couple of ways. To try and enlarge an existing hole, a hole saw is a difficult tool to use. While a "step drill " (I'm not sure about that terminology) or unibit, is designed to go from one size hole to the next. The only limiting factor (If the bit's max size is the same as the desired hole size) is shaft length and chuck interference. Otherwise, it's probably the best tool for the job.
Throw in one with an 1 3/8" max, and it becomes impossible.
It is possible with a bi-metal hole saw, but extremely difficult, as you have you make a guide block to guide the saw, and clamp both pieces together. In solid material from the start, the hole saw wins.
  #20
Old 12-15-2017, 10:34 AM
Quote:
That's a nice looking frame. I'm going to check that out later.
---------- Post added at 11:34 AM ---------- Previous post was at 11:32 AM ----------
I have a bunch of Lenox and Milwaukee bi-metal holes saws for wood. But I know from experience that even hitting a (soft) nail will do damage to them. Those are not meant for cutting mild steel. they're pretty expensive too...and it's getting harder and harder to find the old-timers with a shop who actually can sharpen these things (and Forstner bits and a bunch of other stuff).
Closed Thread
