Closed Thread
Old 09-15-2017, 05:37 AM
HOT_SINCE_81 HOT_SINCE_81 is offline
Junior Member
Default My Gixxer Kart: Ignition help
Hey guys, I'm a new member here so I guess this can serve as an introduction as well. So hello all! I live OC Cali and have no experience building go karts other than what I have learned over the past month breathing life into my current project.
Here's what I have...
Complete custom build from the ground up. Originally was going to put 2 Predator 660cc motors on the kart. After considering that was going to cost me about $1,400 just for the motors I figured why not go with a street bike motor and get 5 times the HP for less money. So I scoured Craigslist for all of 2 days and came up on a totaled Suzuki GSXR 750. Guy hit a stone mailbox after his throttle stuck cracking the frame. Guy said the motor was fine but couldn't start it bc in the accident his key broke off inside the ignition so I rollled the dice and picked it up for $700.
Turns out the motor is just fine and no issues. Yet. So I got some steel square tube and went to work. Knowing this thing is gonna haul *** I opted for 1 1/2" x .188 square tubing which i know ifs overkill but if I'm going to anywhere near 100 mph in this thing I'd rather opt for over engineered than dead.
Here's some pics of my kart.
So I got the motor running strong, frame welded together, all wiring done but I'm stuck at the ignition. This is the stock ignition...
And these are the wires coming off of it.
I've looked high and low online and I can't find anything that can clue me in to what each wire does and how to assimilate them into a new ignition. Right now the stock ignition is temp mounted to one of the frame rails.
Soooo, I'm hopefully there may be another Gixxer Kart owner on here that can help me out.
Glad to me a member here and appreciate any help you all can kend and hope to help you all in the future as well.
Old 09-15-2017, 07:36 AM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Cut the itty bit blue wire.
Sorry I'm no help.
Cool project.
Old 09-15-2017, 07:51 AM
ezcome-ezgo's Avatar
What year is the Suzuki GSXR 750?
Old 09-15-2017, 02:14 PM
Bbqjoe Bbqjoe is offline
Banned
That's a sick kart.
You need help.
Old 09-21-2017, 01:18 AM
Junior Member
Quote:
It's a 2003
---------- Post added at 11:18 PM ---------- Previous post was at 11:15 PM ----------
Quote:
Originally Posted by Bbqjoe View Post
That's a sick kart.
You need help.
Thanks Bbqjoe, looking forward to running it real soon.
Old 09-21-2017, 07:40 AM
Zazoom
  #7
Old 09-21-2017, 10:13 AM
anderkart's Avatar
anderkart anderkart is offline
Hot Since 81:
That wiring diagram ^^^ posted above is for a 1991-1993 GSXR-750. It does not match the colors and number of wires of the Ignition Switch wiring picture you posted.
I checked the wiring diagram for the 2000-2003 GSXR-750. It also does not match the colors and number of wires of your Ignition switch wiring picture...
Are you absolutely sure your engine & wiring harness is from a 2003 GSXR-750?
Or, is that just what the guy that sold it to you said?
I can probably help you figure out your wiring, but first we need to be absolutely positive about the year and model we're dealing with here...
Here's a link to the Suzuki website, where you can match the VIN & and engine serial numbers up to the correct model & year: http://www.suzukicycles.org/_misc/identification.shtml
The Following 2 Users Say Thank You to anderkart For This Useful Post:
ezcome-ezgo (09-21-2017), leesiel (09-21-2017)
Closed Thread
