Closed Thread
Old 09-11-2017, 07:02 PM
VirtualGod VirtualGod is offline
Default Pull Start Won't Pull Sometimes
Hi guys, I got my engine, put some fuel, put some 5w30 oil (I accidently poured it to ground ) So oil is low on oil-level stick thing.
Started few times, it was ok.
But after a week, I tried to pull the cord but it locked after a turn, and because of that, engine levitated to right from left a bit (Pull-start side of the engine)
How can I fix that? It's soooo hard to start right now, I have to find the correct spot to pull it.
Old 09-11-2017, 08:08 PM
OzFab's Avatar
OzFab OzFab is offline
So, no mods to the engine, correct?
Remove the spark plug, pull starter; does it turn easy? does any fluid come out the plug hole?
Quote:
That's called a dipstick, dipstick
Old 09-11-2017, 08:52 PM
MTNSleder MTNSleder is offline
Banned
This sounds like a problem with your pull start..
Take the pull starter off and see if it pulls easily and any thing looks broken... IDK
The Following User Says Thank You to MTNSleder For This Useful Post:
George Norlans (09-11-2017)
Old 09-12-2017, 04:10 AM
What is that fluid? Gasoline or oil? Should I put something under it to get the fluid
Old 09-12-2017, 05:38 AM
I removed the pull starter, turned a bit then stuck again. But I think it has a pattern.
Can't remove the spark plug because the wrench that comes in box is designed by an idiot.
When I try to fit it to spark plug, it collides with spark cable.
I'm going to get a hex-wrench set. (Or socket set whatever it is )
Old 09-12-2017, 06:36 AM
mckutzy mckutzy is offline
Take the cable off and move out of the way.....
Insert socket and turn....
How about some pics....
Where abouts are you located... Fill in your location....
  #7
Old 09-13-2017, 05:15 PM
I can't remove the spark plug, so hard to turn.
  #8
Old 09-13-2017, 07:01 PM
Bbqjoe Bbqjoe is offline
Banned
Quote:
China. Just like the last time.
Hi Poobly!
  #9
Old 09-24-2017, 05:01 AM
I removed the spark plug and pulled the starter, it turns easily. But when I screw the spark plug back, it's hard to pull again And fluid didn't come out. What can I do?
  #10
Old 09-24-2017, 10:16 PM
OzFab's Avatar
There should be some resistance, that's called compression but, not excessive, you should still be able to pull the starter...
  #11
Old 09-25-2017, 03:59 PM
Kleyny Kleyny is offline
My guess is the cam de-compression mechanism is playing up.
If you had trouble with the spark plug removal, removing the cam is going to be fun.
  #12
Old 09-26-2017, 08:08 AM
So how can I fix that? It wasn't like that before As I said it turns easily when the spark plug is removed.
  #13
Old 09-26-2017, 04:22 PM
http://www.diygokarts.com/vb/showthread.php?t=37727
This thread goes into the de-compression mechanism a bit more for you to get an understanding of what it does.
You need to pull the side cover off to remove and inspect the cam.
  #14
Old 09-26-2017, 09:20 PM
OzFab's Avatar
I'm starting to think someone may have already done that but, I could be wrong...
The Following User Says Thank You to OzFab For This Useful Post:
B_Bimmer (09-26-2017)
  #15
Old 09-26-2017, 11:45 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
A virtual god should not be having any problems whatsoever with a puny engine made by mortal men.
Did you forget to eat your Wheaties?
Egad, man, what engine do you have? Where's the dadgum photos, drawings or at least a pathetic description of the engine manufacturer and model, horsepower, or engine size in cubic centimeters?
  #16
Old 09-27-2017, 11:04 AM
But I don't have a torque wrench, is that a problem? And I don't think that I can put it back
---------- Post added at 08:04 PM ---------- Previous post was at 08:03 PM ----------
Generic 6.5hp 196cc engine Gonna add photos soon.
  #17
Old 09-27-2017, 03:59 PM
a torque wrench is not mandatory but a good to have tool for the side cover bolts.
You tube has some videos on how to disassemble these little engines, then just concentrate on the side cover and cam bit.
  #18
Old 09-27-2017, 06:21 PM
Hellion's Avatar
...Gonna add photos soon.
Photos FIRST, always, unless wasting time is something you enjoy.
Even if you enjoy wasting time, you're wasting everyone else's time.
What I thought might be a broken or half-working recoil starter might just be your weakness.
Better eat those Wheaties and report back tomorrow.
  #19
Old 09-27-2017, 08:39 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
These go on sale for $10 each at Harbor Freight. I recommend getting all of them when they do.
http://www.ebay.com/itm/Set-of-3-Pro...MAAOSwa~hZZt8L
https://www.harborfreight.com/1-4-qu...ench-2696.html
(Good for ARC Connecting Rod Bolts)
https://www.harborfreight.com/3-8-ei...rench-807.html
https://www.harborfreight.com/1-2-ha...rench-239.html
I got this one from sears
http://www.sears.com/craftsman-3-8-i...FVCraQodXLEMuA
Never tried one of these
https://www.harborfreight.com/12-in-...ter-68283.html
Here's a cheap one on ebay.
http://www.ebay.com/itm/Torque-Wrenc...AAAOSwXvNZuj~L
  #20
Old 09-28-2017, 01:55 AM
What photos exactly you need? Engine or compression thing?
---------- Post added at 10:55 AM ---------- Previous post was at 10:07 AM ----------
Quote:
Originally Posted by bob58o View Post
Can I just mark those bolts with marker and unscrew them
Closed Thread
