Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 08-31-2013, 02:50 PM
rm250karter rm250karter is offline
Petrol head
Default 2008 gs moon buggy road legal with a honda cbr900rr fireblade :)
Here's my 2008 gs moon road legal buggy which I'm planning on fitting a 1999 Honda cbr900rrx fireblade engine too
Ill go through it fast as its already nearly finished so try and keep up. It's been a long stressful EXPENSIVE project but its been worth every bit of it
ENJOY.
Old 08-31-2013, 02:56 PM
Petrol head
Some pics of my buggy as I bought it.
Only had one owner from new
18bhp single cylinder 260cc
0-60 is never as it never gets to 60 !!
50mph max
Dry weight is 350 kilos
80951b28-7781-4c5d-8897-c99085edb451.jpg   b2acbc92-23cf-40d9-a28a-14af0c2c9081.jpg
7e95588e-857d-4a85-85cd-efbf9a7ced14.jpg   1012194_10152033409078942_256150483_n.jpg
Old 08-31-2013, 03:40 PM
mysteryboy28's Avatar
mysteryboy28 mysteryboy28 is offline
where's the pics?
go back and edit your posts. click "go advanced", then manage attachments, the click to browse computer for pictures, upload, and submit. done!
The Following User Says Thank You to mysteryboy28 For This Useful Post:
rm250karter (09-01-2013)
Old 09-01-2013, 02:10 AM
Petrol head
Original 260cc 15bhp engines out.
f02edd5f-0afd-4c03-8740-012084d83b48.jpg   cbb0ddaa-ab67-4d88-aa13-ac6c7e05ba03.jpg
93f2fdee-319c-4dbd-af4a-243265510c5b.jpg   1002566_10152033410183942_1684578227_n.jpg
994516_10152033410118942_900133554_n.jpg   62817_10152033410233942_1198608464_n.jpg
Old 09-01-2013, 02:16 AM
Petrol head
1999 Honda cbr900rrx fireblade engines going in.
Produces about 150bhp which should be fun in something that weighs 450kg
993293_10152033410593942_697851128_n.jpg   1001856_10152033410748942_880567891_n.jpg
972223_10152033410848942_1076768443_n.jpg   46820_10152033410943942_1911284104_n.jpg
Old 09-01-2013, 02:34 AM
Petrol head
Engines nearly in, hope you like the engine crane lol
Mounting a 4 cylinder 900cc engine where a single cylinder 260cc used to be isn't easy !!
I had to modify the brake pedal and move the master cylinder over to the right to allow enough room for a clutch pedal that I've got to make.
1069912_10152033411028942_1151942468_n.jpg   988632_10152033411183942_719521374_n.jpg
263301_10152033411228942_2026539378_n.jpg   995714_10152033415173942_2060352703_n.jpg
46784_10152033415258942_1660421669_n.jpg   72913_10152033415298942_915043405_n.jpg
  #7
Old 09-01-2013, 02:40 AM
Petrol head
Starting to mount the engine in now
998511_10152033415418942_1373481188_n.jpg   154433_10152033415643942_1261362732_n.jpg
999698_10152033415798942_1004253018_n.jpg   992924_10152033415698942_1185088244_n.jpg
1002980_10152033416018942_259439132_n.jpg   14772_10152033416118942_1144724094_n.jpg
  #8
Old 09-01-2013, 02:44 AM
Petrol head
More engine mount pictures.
Got fed up of using a spirit level now but it's in perfectly straight and level.
Took a little while deciding where to put the engine mounts but its looking good atm.
69202_10152033416073942_1271829981_n.jpg   1006157_10152033415958942_1399636727_n.jpg
1069326_10152033416278942_770272767_n.jpg   945406_10152033416388942_2098539607_n.jpg
  #9
Old 09-01-2013, 02:50 AM
Petrol head
Engines all mounted now.
Coils and air box are mounted.
Fuel tank mounts have been moved on top of the luggage rack as the engines in the way now.
1016337_10152033416458942_1849724747_n.jpg   28168_10152033417068942_922647764_n.jpg
64110_10152033416503942_733312199_n.jpg   999650_10152033416733942_1525381841_n.jpg
1011524_10152033416663942_1176815387_n.jpg   1011492_10152033416973942_460481464_n.jpg
  #10
Old 09-01-2013, 02:54 AM
Petrol head
Fuel tanks moved on top of the engine as its gravity fed into the carbs.
Gear selector has been made up, just need to make up all of the connecting rods ie turnbuckles, im using rose joints too.
21376_10152033416863942_210112911_n.jpg   72911_10152033416798942_110157872_n.jpg
1017510_10152033422893942_2001771229_n.jpg   1009786_10152033424098942_1092586138_n.jpg
996815_10152033425178942_1824307033_n.jpg   934611_10152033422973942_514340918_n.jpg
  #11
Old 09-01-2013, 03:01 AM
Petrol head
Gear selector mounted.
New full micron exhaust system bought for it.
A set of autograss gaz fully adjustable coilover suspension I've bought.
A picture of the dreaded wiring loom which I've got to sort out.
A picture of the ford sierra cosworth LSD with pivot plates chain converted with a 530 sprocket.
Last picture is the fireblade engine when I bought it.
21396_10152033425308942_352278834_n.jpg   1000841_10152033427193942_1708499322_n.jpg
1004446_10152033426673942_364915896_n.jpg   992820_10152033426958942_258029665_n.jpg
992923_10152033427473942_769231352_n.jpg   1069392_10152033427878942_1339839977_n.jpg
  #12
Old 09-01-2013, 03:09 AM
Petrol head
Diff being mounted which wasn't easy !!
Getting it perfectly inline and level with the engine was hard but with time I got it done.
I'm a perfectionist and everything I do has to be perfect which is great but it just takes me hours and hours to do anything !!
It's starting to take shape now
1010066_10152033428418942_865050968_n.jpg   1069265_10152043962018942_125450163_n.jpg
1005736_10152043962503942_102592526_n.jpg   1005980_10152043962848942_1847155610_n.jpg
546846_10152043962963942_897309299_n.jpg   1013446_10152043963093942_1944094330_n.jpg
  #13
Old 09-01-2013, 03:12 AM
Petrol head
Still mounting be diff !
I'm using 25mm box section which is 3mm thick so it's plenty strong enough.
1005641_10152043963728942_180677976_n.jpg   942728_10152043964048942_863302237_n.jpg
1016228_10152043964183942_714849836_n.jpg   969013_10152043963468942_1689840511_n.jpg
971542_10152057528133942_173178080_n.jpg   999808_10152057528458942_1005855567_n.jpg
  #14
Old 09-01-2013, 03:15 AM
Petrol head
Still mounting the diff !
Also mounted the bottom engine mount to the box section which was convenient
24623_10152057528548942_2058060185_n.jpg   999653_10152057528658942_636315546_n.jpg
1003343_10152057528248942_1481874825_n.jpg   999407_10152057528923942_1388915983_n.jpg
1069172_10152057528803942_830655383_n.jpg   521605_10152057528983942_612281907_n.jpg
  #15
Old 09-01-2013, 03:17 AM
Petrol head
1016860_10152059431698942_1030852248_n.jpg   1010377_10152059431798942_1191886061_n.jpg
1012043_10152059432903942_1566597105_n.jpg   970965_10152059433168942_1930938982_n.jpg
18974_10152059431883942_318959609_n.jpg   311659_10152059432018942_747220050_n.jpg
  #16
Old 09-01-2013, 03:19 AM
Petrol head
Diff frame all made and finished thank god !
999839_10152059433268942_884142371_n.jpg   998757_10152059433338942_2033627230_n.jpg
543740_10152059433438942_1390729158_n.jpg   1012017_10152059433703942_850117018_n.jpg
67446_10152059433793942_1878653234_n.jpg   993333_10152059434103942_1072095105_n.jpg
  #17
Old 09-01-2013, 03:21 AM
Petrol head
Diff frame back on the buggy.
Ruler showing sprockets are perfectly inline
534840_10152059434353942_1997702243_n.jpg   1000522_10152059434203942_498170552_n.jpg
1009823_10152059434278942_602095274_n.jpg   1069325_10152059433948942_414215091_n.jpg
993944_10152059434643942_655611393_n.jpg   15063_10152059435088942_1269713786_n.jpg
  #18
Old 09-01-2013, 03:25 AM
Petrol head
Now the hard part trying to work out where to mount the exhaust, I've finally decided to mount it coming straight out of the back in the middle as the picture shows.
I've cut down the rear silencer to make it smaller so it'll fit better.
1017707_10152059434743942_622367299_n.jpg   1011347_10152059434483942_1541321318_n.jpg
1001226_10152070522493942_527774573_n.jpg   1098285_10152070522638942_60094656_n.jpg
935837_10152071264058942_1047066391_n.jpg   995959_10152071264818942_984548971_n.jpg
  #19
Old 09-01-2013, 03:30 AM
Petrol head
Exhaust finally finished it took me 2 days just to cut a tube 3" long which had 4 different angles on it ! Was a right pain in the arse nearly gave up on it !!
993961_10152086998513942_1378775207_n.jpg   1150410_10152086998743942_160769380_n.jpg
537169_10152088741358942_689767013_n.jpg   1146743_10152088743178942_112447851_n.jpg
994573_10152088743108942_143934098_n.jpg   968906_10152088766723942_717275476_n.jpg
  #20
Old 09-01-2013, 03:35 AM
Petrol head
Exhaust all done and mounted now.
Started making the gear linkages up. Done one just need to make the other one now.
Hope you like what you see
1002571_10152071264263942_1681241722_n.jpg   24281_10152071264518942_1986049862_n.jpg
999557_10152088767298942_731184510_n.jpg   969842_10152088767078942_568174177_n.jpg
Closed Thread
