Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Closed Thread
Old 05-30-2013, 11:59 PM
dreazoian dreazoian is offline
Default 49cc Cateye Pocket Bike
I got a cateye fs509 pocket bike. i bought it used off craigslist. I was told the pocket bike had been sitting for about 2 years but after about 10 pulls i got it to turn on, i could take it for a test drive because the tire was flat. i got home pumped up the tire, and when i wanted to take it for a spin i noticed it barely goes like 3mph. I used to have another cateye a few years ago and it did like 45mph downhill and 38 on flat road. when i sat on it id throttle it and it would start revving at full rpm but barely move. I thought maybe the carb needed adjusting. after adjusting the idle screw, i got it to go about 2mph faster and i felt some kicking everytime i tried to ride it then found out my clutch was slipping. opened it, it was worn out and so i went and bought a new one. I installed the new one, no difference, retuned it, 2 mph difference. I do not know what else to do so if any of you have an idea as to what could be the problem please help!
Old 05-31-2013, 12:19 AM
souperman000's Avatar
souperman000 souperman000 is offline
How many teeth on the axle sprocket and the clutch sprocket? It may be a gearing issue, it may not, but its a good place to start.
It's hard to help people that won't help themselves.
Old 05-31-2013, 12:25 AM
Quote:
i may not be exact because it was kinda dark but its like 45 axle and 15 on clutch sprocket.
Old 06-02-2013, 12:09 AM
Im starting to think that maybe it may not be the right clutch or i just did not put it on correctly. Should i put up pics?
Old 06-02-2013, 08:03 AM
machinist@large's Avatar
machinist@large machinist@large is offline
Quote:
Yes!!!! By all means, post pic's!!!
Old 06-02-2013, 09:05 AM
ML-TOYS's Avatar
ML-TOYS ML-TOYS is offline
Are you getting full rpm's ?
Does it have fresh fuel ?
Did you thoroughly clean the gummed up carb that sat for 2 years ?
Did you replace the spark plug ?
Is the air filter clean ?
This is most likely a motor maintenance issue rather than gearing. Most people do not change the stock gears without building up a motor first on these.
  #7
Old 06-02-2013, 01:59 PM
1. yes
2. yes
3. currently in the process of doing.
4. no il do that
5. i removed it because it was old and dirty. how can i clean it?
  #8
Old 06-05-2013, 10:55 AM
oscaryu1 oscaryu1 is offline
Check your CVT.
  #9
Old 06-05-2013, 12:15 PM
Quote:
Originally Posted by oscaryu1 View Post
Check your CVT.
Check what? i already replaced the clutch what else is there to do?
Closed Thread
