Closed Thread
Old 02-08-2011, 08:10 PM
spudkilla224's Avatar
spudkilla224 spudkilla224 is offline
Default Mini Glass-Pack Or Fart Can For GX-160?
Does anyone know of any companies that would make a glass pack or fart can muffler small enough that would work with a GX-160 Clone? I can weld, and machine an adapter if I need to, But i don't want a large, out-of-place muffler on a little GX-160.
Old 02-08-2011, 08:35 PM
Doc Sprocket's Avatar
I don't think there's a lot out there for "custom" exhausts. A lot of guys run open/straight pipes. Some folks adapt dirtbike mufflers and the like, and a few of us just fabricate what we're after.
Old 02-08-2011, 08:50 PM
yeah thats the nice thing about fabrication. what kind of fiberglass filling could I use to make a glass pack "filler"?
Old 02-09-2011, 08:29 PM
I've heard of guys using stainless steel wool pot scrubbers.
As for glass, I dunno what you can lay hands on. Normal insulation will likely just burn out.
Old 02-09-2011, 08:36 PM
r97's Avatar
r97 r97 is offline
Measure twice cut once
crush up some glass bottles?
Old 02-09-2011, 11:05 PM
mini chopper mini chopper is offline
http://www.bikebandit.com/moose-fibe...LAID=338443253
i plan on making a muffler with this stuff one day. always heard great results
  #7
Old 02-10-2011, 12:17 AM
Russ2251's Avatar
Russ2251 Russ2251 is online now
AZUSA:Powered by LAWN-BOY
Glass packs use fiber glass...hence the name.
Try burning reinforced packaging tape. The paper burns away, but the fiber glass remains viable.
Those that can...do. Those that can't...buy a predator.
  #8
Old 02-10-2011, 04:56 AM
They do, but I think they use a fairly coarse fibre. The stuff that we can commonly attain as insulation is quite fine. From personal experience, it burns away pretty easily, too. I'm not confident it would last very long in an exhaust system.
But- One could always try!
  #9
Old 02-10-2011, 06:26 AM
Russ2251's Avatar
I am.
I recently had a glass pack rust through. The stuff that blew out was identical to what is used in fiber glass repair kits.
Steel wool will not work.
  #10
Old 02-10-2011, 11:45 AM
The Mechtician's Avatar
The Mechtician The Mechtician is offline
Gargamel Jr.
I've used Emgo shorty mufflers on tons of machinery over the years, they're about $17 each from Dennis Kirk. I think JC Whitney sells 'em too. Here's what they look like:
  #11
Old 02-10-2011, 02:39 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
http://diygokarts.com/vb/showthread....memade+muffler
You could use a smaller outer shell if you want.
ASE Certified
  #12
Old 02-10-2011, 04:03 PM
Woven cloth, or matt?
Not the standard, hardware-store mild steel. I refer to a very coarse stainless material sold as pot scrubbers. I'm reasonably sure they'd work. It's all academic 'till somebody tries it, though.
  #13
Old 02-10-2011, 04:08 PM
devino246's Avatar
Quote:
hmmm...
ASE Certified
  #14
Old 02-10-2011, 05:13 PM
redsox985's Avatar
redsox985 redsox985 is offline
I was thinking of making my own sometime. Could I use a paint can lined with coarse steel wool and a perforated inner tube to keep the steel wool inside the can? I'd make a new header flange and extend this to the homemade muffler can. Would this kill any sound? I want to make a quieter muffler that doesn't choke the engine so I can ride in my neighborhood.
  #15
Old 02-10-2011, 05:17 PM
devino246's Avatar
Quote:
see above link.
Quote:
Originally Posted by devino246 View Post
ASE Certified
  #16
Old 02-10-2011, 05:28 PM
I don't see why not! Give it a go, and if it doesn't work out what have you lost? A few bux in pot scrubbers (dollar store, no doubt) and some labour...
In my mind, experimentation is in the true spirit of this site. DIY!
  #17
Old 02-10-2011, 08:43 PM
kibble's Avatar
kibble kibble is offline
I banned myself
"At the enrichment center we believe that if at first you don't succeed, you fail." GLaDOS - Portal
  #18
Old 02-10-2011, 08:47 PM
redsox985's Avatar
I'll stop in and talk to my shop teacher tomorrow. I'm out of shop now that my kart is done. I took Metal Tech 1-4 and then 4 again to finish the kart!
Closed Thread
