Old 07-18-2019, 02:07 PM
J.S.@SMS J.S.@SMS is offline
Here 8am-? Mon-Fri
Default Tc dry lube recommendations
Itís been a while since Iíve been on here with the summer and my job, but I have a question about what type of dry lube to use on a torque converter. Iíve seen two at Home Depot, a dry lube with Teflon, and a dry graphite lube. Which is better for a 30 series?
And, on an unrelated topic, is it too late to enter the build off?
J.
Old 07-18-2019, 02:56 PM
Mrmonk7663 Mrmonk7663 is online now
You could always order the Comet Lube online. It’s about $20.
Old 07-18-2019, 11:47 PM
landuse's Avatar
landuse landuse is offline
I would use the graphite dry lube
Old 07-19-2019, 01:38 AM
Tpdingo Tpdingo is offline
Graphite Dry Lube works fine for me. Teflon is junk.
Old 07-19-2019, 07:02 AM
Here 8am-? Mon-Fri
Ok thanks. I’ll get some next time I’m at HD.
Old 07-19-2019, 10:55 AM
Originally Posted by J.S.@SMS View Post
Ok thanks. Iíll get some next time Iím at HD.
Blaster Graphite Dry Lube at HD is the stuff to get it works fantastic.
