Old 07-07-2019, 12:17 PM
4EyedTurd 4EyedTurd is offline
Default Go kart as a trailer mover?
Iíve got 3 go karts and 1 minibike, when they run they are fun but my old trailmaster buggy has just been a money pit. Iím not impressed with the GY6 so far. I posted it for sale and at the same time realized I might be able to use it for something else I need, a trailer mover. My backyard is small so pulling a 16 or 18í car hauler trailer in can be done, turning it around canít with a full-size truck.
My thought was, the buggy already has rubber filled tires, mount a receiver hitch. Replace gy6 setup with a predator engine with a reverse gearbox, probably use a torque converter unless a clutch is mandatory, gear way down and use it to move an empty trailer around the yard.
Thoughts/criticisms/concerns??
Old 07-07-2019, 12:47 PM
Currently flathead-crazed
Should be fine, bur make sure to brace the frame where you mount the hitch.
I'll be watchin' this thread.
Local Bird Engineering Nut
Old 07-07-2019, 03:06 PM
bthompson224's Avatar
bthompson224 bthompson224 is offline
Sell it and get a four wheeler. With that stress, it will only get worse. I use a hand pulled trailer dolly.
Old 07-07-2019, 03:22 PM
I don’t know but I think a predator will solve 90% of my frustrations. Throw a new master cylinder on it, receiver hitch will be cake and motor/gearbox will be simple just $200 plus sprockets,chain and the little pieces. I’ve seen 2 trucks on YouTube that are setup with a predator 212 driving the factory transmission. If I can gear it down enough I’d like to use a 212 so I won’t need a battery.
Old 07-07-2019, 03:27 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Good call. Utility style 4-wheelers; they're beasts.
But a trailer dolly, like this?
Old 07-07-2019, 04:21 PM
But Hellion,
That's just too hard!
Old 07-07-2019, 05:25 PM
How easy is it to move a 18’ car hauler on grass? I may try one
Old 07-07-2019, 06:14 PM
Hellion's Avatar
Originally Posted by JTSpeedDemon View Post
But Hellion,
Eat your Wheaties, tadpole. You're lookin' kinda wormy.
Old 07-07-2019, 06:29 PM
anickode's Avatar
anickode anickode is offline
I'd be concerned that even the empty tongue weight on an 18' car hauler would be more than your average go kart axle and suspension will take.
I use my garden tractor. It's plenty beefy.
"Well that would be a bomb."
Old 07-07-2019, 06:32 PM
Originally Posted by 4EyedTurd View Post
How easy is it to move a 18í car hauler on grass? I may try one
I've used it on several boats up to 22 foot, plus empty trailers of various sizes. Even uphill. Not easy peasy, but not really hard either. Certainly not if it had a car on it. Plenty hefty enough if the trailer is correctly balanced.
  #11
Old 07-08-2019, 04:01 PM
txluke txluke is offline
Gear it low and go!
  #12
Old 07-08-2019, 07:18 PM
Bansil's Avatar
Bansil Bansil is offline
Okay, so noone moves trailers in tight areas , screw the go cart idea. 2 options IMO front hitch on truck...serious money maker, next choice would be a small tractor
  #13
Old 07-08-2019, 07:41 PM
Kartorbust's Avatar
I have before and we just used a full size truck and old fashion muscle if we needed to move it further over. We did try using a lawn tractor to move a boat trailer, however, we did not take into account the tongue weight too much and the tractor lifted the front tires off the ground. Needed about 150lbs of counter weight for it. I'm not a big guy (maybe 160lbs soaking weight) and I've had to heft a loaded boat trailer over a bit to get the truck lined up with it. Not an easy task, but doable. Only reason I had to was because the jack wheel would dig into the ground (grass and gravel).
  #14
Old 07-09-2019, 05:45 AM
I do. Back it through the gate and grab the dolly. Most boat yards around here use a 4 wheeler. Again, depends on the tongue weight. For most empty trailers that's under 50 pounds if correctly balanced.
  #15
Old 07-09-2019, 09:58 AM
mckutzy mckutzy is online now
If you search on diy electric trailer dolly, youll get a ton of links...
Off hand here is one, buddy used a atv winch to motorize his tug...
https://www.proud-canadian.com/diy-power-trailer-dolly/
  #16
Old 07-09-2019, 10:42 AM
Budget GoKart's Avatar
broke mechanic
A lawn tractor has tight steering especially newer ones thats your best bet but a low geared 212 can do almost anything
Certified Yerfdog 3202-3203 expert.
  #17
Old 07-09-2019, 12:15 PM
Well, if I can find someone to buy the buggy I’ll try one of those dollies.
  #18
Old 07-09-2019, 02:29 PM
karl's Avatar
karl karl is offline
Sound like you need a chair
beefy hydro garden tractor axle (tuff torq k65), easy foot drive
cast iron front axle (from IH cub)
rack and pinion steering (from cub PRO Z commercial )
extremely short wheelbase , tight turning radius
covers all the bases, throw a ball on the front and back, call it a day.
All for the cost of welding wire , oil, and a v belt
  #19
Old 07-09-2019, 02:59 PM
I like it but I also like that cub cadet in the back
  #20
Old 07-09-2019, 09:14 PM
420Racer 420Racer is online now
Rip It Up
I like that electric dolly
