  #21
Old 06-24-2019, 09:30 AM
bthompson224's Avatar
bthompson224 bthompson224 is offline
Good pics in this thread, looks like the diff is under the engine.
http://www.diygokarts.com/vb/showthread.php?t=33886
  #22
Old 06-24-2019, 10:56 PM
Denny Denny is offline
If you look you can see the sprocket for the axle bolted right to the differential. It is also next to the brake disc. It is in no way shape or form a 388 series they are closely related to the Dingo. This kart is bigger.
  #23
Old 06-25-2019, 05:50 AM
Karttekk Karttekk is offline
Some of the drivetrain parts in the exploded illustration seem to match pretty closely but yes, the kart pictured is a 2 seater and the 388 is a single seater model. If there were a way to find out what other models shipped with that drivetrain we might be able to identify it.
  #24
Old 07-08-2019, 12:28 PM
Plamondacheq Plamondacheq is offline
Okay so pulled the the motor, decided to rebuild it. Pretty sure the axle is a diffential type. As for the brake my caliper appears to float on the mounting bolts that are attach to the bracket. It's a til-0-matic brand caliper and can't seem to find any for sale anywhere. Will any of the manual calipers from go kart supply work? As for the chain I'll have to get measurements due to the rust if is labeled I can find it. Hers some pics if that helps
---------- Post added at 01:28 PM ---------- Previous post was at 01:16 PM ----------
Sorry don't know what's up with the water marks from Photobucket, first time it's done that.
  #25
Old 07-08-2019, 06:00 PM
Also need help finding a brake cable the only numbers on mine are 6747 0433. It measures approximately 54" and has the eyelets for bolts to go through on both ends. Any help would be great thanks.
  #26
Old 07-08-2019, 11:53 PM
landuse's Avatar
landuse landuse is offline
Bicycle brake cable
  #27
Old 07-09-2019, 05:59 AM
Any way to see where that cable connects at the pedal?
