Old 07-24-2015, 08:45 PM
Doodle123 Doodle123 is offline
Default Project minibike probs. PLEASE HELP
I have an old doodlebug minibike that I'm trying to get running. This is my first project minibike, and I've been through the whole engine. Everything looks fine. The kill switch has been cut. Will this cause it not to run? Also, seems like the brakes are locked up a little bit, it will roll but not good. Is there anything I can do to make the brake pad space larger? Thanks for the help.
Old 07-24-2015, 09:17 PM
superballskart superballskart is offline
Banned
Find the wire and ground it to the frame if it starts that's your problem sometimes it needs to be grounded others the ground is what kills it as for brakes adjust the tension at the lever move it to be seated with the lever if it still tight loosen the cable at the caliper and let about 1/8 inch of the wire slide through and tighten it down
The Following User Says Thank You to superballskart For This Useful Post:
2SlickNick (07-24-2015)
Old 07-24-2015, 10:06 PM
Thanks for the brakes. The wire for kill switch has been completely cut. I have a parts bike, so I'll just take it off that one and put it on the good one.
Old 07-24-2015, 10:32 PM
mckutzy mckutzy is online now
Hello and welcome..
Please if you could, fill out your location and post some good pics of your ride. Also post some details of the bike.
Poboy kartman (07-26-2015)
Old 07-24-2015, 10:39 PM
Banned
The wire should be coming off of the magneto if I'm correct....think I am never really tore into any of the doodlebugs but I know I always have leaks in the intake manifold...think its called something else on small engines but its the rubber between the carb and engine every time I pulled the carb off to clean it had to replace gasket to
Old 07-25-2015, 01:11 AM
Alright. Spark plug wire was in bad shape so I tried pulling it off, and ripped off the magneto. Inside the magneto is there supposed to be a pointy thing? Sorry for my lack of knowledge.
Old 07-25-2015, 01:22 AM
Banned
I was alil off on my terms its a ignition coil I'm used to cars and bikes anymore haha and as far as I know the actual coil the part wrapped in plastic should be smooth post a pic if anything that's always the best way
Old 07-25-2015, 08:43 PM
Alright. Got it to where it would start on starting fluid, but when you stop spraying, it cuts off. Is this a dirty carb? I took it off and it was clean from what I could see.
Old 07-25-2015, 09:59 PM
Banned
Could be dirty run a twist tie with the plastic burnt off through your jets be sure to clean main and pilot jet...I think that's the only two or it could be a leak between the carb and engine either way its to lean that's why it runs on starter fluid cause it runs it rich
Old 07-25-2015, 10:14 PM
Great! cleaned the carb, and it runs like a charm! Another problem now. This thing is so hard to push, and it will barely move with no one on it. How do I make it roll freely?
  #11
Old 07-25-2015, 10:35 PM
Banned
If you got your brakes to not rub and its still doing that then u need to grease or replace the bearings in the wheel
  #12
Old 07-26-2015, 02:45 PM
How can I loosen the brakes?
  #13
Old 07-26-2015, 05:44 PM
Banned
I mentioned that in the first post but if they are still tight adjust the tension at the caliper all more....don't pull the wire through let some out and it will let the pad spread....I always loosen the bolt and let all tension off the pads then adjust the pad till they are just about seated to the disk then tighten the bolt....thinking about it you might have a bent disk does its grab all the way around on a full revolution or just certain parts
  #14
Old 07-26-2015, 06:22 PM
Poboy kartman Poboy kartman is offline
Banned
It's time.....
---------- Post added at 06:22 PM ---------- Previous post was at 06:21 PM ----------
Originally Posted by mckutzy View Post
Hello and welcome..
Did you miss this post?
The Following User Says Thank You to Poboy kartman For This Useful Post:
mckutzy (07-26-2015)
  #15
Old 07-26-2015, 07:00 PM
Banned
I was going to say the same but I had so many doddle bugs I know bout everything that messes up on it
  #16
Old 07-26-2015, 09:37 PM
Thanks Poboy...
I was just about to post about this... Where it must be great to know all about stuff and don't need to explain to the rest of us here...
After all I'm just a guy who built all of his stuff and WTF does he know when he's asking for clarification... Pardon me....
Rant off....
  #17
Old 07-27-2015, 01:55 PM
With all due respect.. Slow your roll buddy...
I don't know off hand what a bug is and or what engine it's got, let alone brakes.
If I asked for more pics, that's just the obligatory post...
And no do I want to go google it to find out....
This happens alot of times here, we ask all people to help us help you when posting... I don't think that's too much to ask...
Poboy kartman (07-27-2015)
  #18
Old 07-27-2015, 02:48 PM
Banned
Originally Posted by superballskart View Post
But like a said all posting a pic would do is let you know if its disk or drum and doodle bugs ain't old
Unless it was manufactured in 1946...that would make it pretty old...
  #19
Old 07-27-2015, 07:09 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Look here Nick You 22 yr old little puke. This is not Facebook or U-tube, and your not commenting on some social media garbage you saw on MTV last night.
This is a G rated forum where adults and kids share info and learn about their projects. Your comments about Vibrating plugs up peoples behinds are not welcome here. Go back to junior high and find some friends, I bet a bunch a pimply faced 14yr olds would think you a really cool. But we do not.
Why don't you, go back to your double wide and fry something!
The Following User Says Thank You to chancer For This Useful Post:
Doc Sprocket (07-27-2015)
  #20
Old 07-27-2015, 08:39 PM
Doc Sprocket's Avatar
The problem has been addressed.
Folks- Please keep your language family-friendly.
The Following User Says Thank You to Doc Sprocket For This Useful Post:
landuse (07-27-2015)
