Old 02-20-2013, 10:23 PM
trekklee trekklee is offline
Default Adding a starter to go kart
I found the starter that will fit on my Tecumseh OHH60 but I don't know where it would be mounted if I bought it here's the link for the starter http://www.jackssmallengines.com/Pro...435627/56959/s
Old 02-20-2013, 10:36 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
that starter is 120v for a house circuit, you will need to plug in an extension cord every time to use it
your flywheel has to have a ring gear and your engine block has to have drilled/tapped holes in the front
Old 02-20-2013, 10:39 PM
What do you mean by plugin a extension cord ? And what if I don't have those two holes in front?
Old 02-20-2013, 10:42 PM
souperman000's Avatar
souperman000 souperman000 is offline
For that price, you could just get an engine that comes with electric start.
That starter is designed to be run from an outlet. Since you probably don't have an electrical outlet on your kart, you would need to run an extension cord and plug it in everytime you wanted to use it. Without the holes, you might be able to jerry rig a mount or something. Maybe use some plumber's strap.
It's hard to help people that won't help themselves.
Old 02-20-2013, 10:45 PM
True about the whole new engine but I see people just use like a battery and hook up the wires an have nice keyholes for a key tournament ignition
Old 02-20-2013, 10:51 PM
you would need a starter from a lawn tractor or something then. if you want to have a battery and key start you need a 12v DC starter. they are harder to come by on the tecumseh's.
the starter in the link is 120v AC and made for snowblowers. they do not put batteries on snowblowers because they are used in the cold. this type of starter wont run off a battery
Old 02-20-2013, 10:53 PM
Ok then how do I install a key switch or key ignition or wire it up then? With out the starter
Old 02-20-2013, 10:58 PM
you mean just have a key for the kill switch? does it have a kill switch on it now? you can run the wires to a key switch
Old 02-20-2013, 11:00 PM
Yeah I have a kill switch
Old 02-20-2013, 11:08 PM
If it is hooked up with the switch it has to be on to start the engine right ???
  #11
Old 02-21-2013, 12:15 AM
landuse's Avatar
landuse landuse is offline
That is correct
