Closed Thread
Old 05-29-2019, 10:45 AM
shawn stangel shawn stangel is offline
Junior Member
Default American Sportworks Black widow T/C problems
i just replaced the belt and the brass bushing and i can roll the kart backwards about 3 feet before the belt/tc tightens up to where i cant budge it unless it is rolled forward
Old 05-29-2019, 11:53 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Is your chain alignment off?
Currently Flathead-Crazed
Old 05-29-2019, 01:38 PM
Junior Member
chain alignment looks good
Old 05-29-2019, 01:47 PM
Are your axle/wheel bearings good?
My go kart, before I replaced the bearings, the chain would go tight, loose, tight, loose.
So that could be a problem.
Old 05-29-2019, 05:16 PM
950speed's Avatar
950speed 950speed is offline
Is there a washer between the jack shaft sprocket and driven pulley? If not the chain will bind on the pulley rivets
Old 05-29-2019, 06:10 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
what about belt alignment?
If it's not scary you're not going fast enough
  #7
Old 05-29-2019, 07:21 PM
950speed's Avatar
Bet alignment shouldn’t matter, it’s a circle so if it flexes at one point in the circle it will continue to flex and bend, belt alignment shouldn’t matter. It would have to be super dry rotted and hard to cause that problem if it wasn’t aligned the proper way
  #8
Old 05-30-2019, 01:09 AM
landuse's Avatar
landuse landuse is offline
Has this problem started only since the belt an bushing were replaced? Have you got the correct size belt for your TC? Post some pics of the TC and belt
Look here to make sure you have the correct belt
https://www.gokartsupply.com/tcbelts.htm
Closed Thread
