Closed Thread
  #61
Old 05-28-2019, 11:20 AM
Bmr4Karts Bmr4Karts is offline
Found a couple more karts that I aspire to build mine into (minus the gas engine).
The owner of the white kart stated it is a Manco Dingo 285. This all the stuff they posted on GPS.
Quote:
74.5" Manco Throttle Cable, total length 81", Brake Puck, Manual Caliper, Manco Live Axle Sprockets #41/420 Chain, 5/8" Jackshaft Lock Nut, Axle 40"-- 1" diameter, 1" or 7/8" H, Axle Bearing (Manco 3941 & 3941H), 1/4" Key, 1 1/4" long, AZ8435 / 6123, Jackshaft Lock Collar 5/8", Axle Lock Collar 1", Chain Connector Master Link, 30 Series Torque Converter 3 pc Kit, #420 Style Chain, choose length, 6 x 6.5 Black Douglas (DWT) Wheel, 1" Sprocket Carrier Sprocket Hub, Front Hub Dual Mount Black, 6 x 9.25 Black Douglas (DWT) Wheel, 1" Hub Dual Mount Black, Mounting Pack, 11 x 6.00-6 Unilli Tire, 12x9.00-6 Unilli Tire
I like the tires a lot but those wheels are ~$40 each. Gotta be a cheap set out there.
Closed Thread
