Go Back   DIY Go Kart Forum > Other Stuff > Crazy Craigslist Finds
Old 04-21-2016, 02:23 PM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
Default Single Cylinder Carb. 10-25 HP Nitrous Oxide System
10 - 25 HP Wet Nitrous. Come On!!!
"Direct-port system for carbureted single cylinder engine. Includes our exclusive "PROTON" solenoid assembly,braided stainless hoses,Piranha nozzle,fuel pump, relay,microswitch, arming switch, jetting for 10,15,20 and25HP.1.0 lb bottle and two stainless steel bottle brackets.
http://www.nitrousexpress.com/61025-...lb-bottle.html
---------- Post added at 03:20 PM ---------- Previous post was at 02:43 PM ----------
WET NOS JETTING
https://www.dynotunenitrous.com/stor...ousjetcalc.asp
1) Input Wide open throttle fuel pressure
2) Input Nitrous Pressure in the bottle before a run
3) Input Horsepower wanted, press "Recalculate"
4) Use the jet sizes listed below for Nitrous and Fuel
Note: This Calculator is for a single fogger nozzle wet system. This will get you close on the tune but Dyno testing with a wideband o2 gauge is highly recommended. DynoTune assumes no liability, use this calculator at your own risk!
---------- Post added at 03:23 PM ---------- Previous post was at 03:20 PM ----------
A DIY'er might try the cheaper whip cream charger set up combined with a fogger nozzle and some small engine pilot jets?
http://www.jegs.com/i/Nitrous+Expres...sGZRoC_Mfw_wcB
There are two types of people. Those who can extrapolate data
Old 04-21-2016, 04:12 PM
Jrgunn5150's Avatar
Jrgunn5150 Jrgunn5150 is offline
Rudderless
I had nitrous on one of my RC's about ten year's ago, an HPI Savage with an OS .32 "Big Block", didn't make a noticeable difference, did look awesome.
You would definitely want a wet kit, a plate if available.
The Following User Says Thank You to Jrgunn5150 For This Useful Post:
bob58o (04-21-2016)
Old 04-21-2016, 05:00 PM
bob58o's Avatar
Seems really cool. Depending on jetting, I'm sure you could make the difference noticeable.
BOOM.lol
Who likes dice?
The Following User Says Thank You to bob58o For This Useful Post:
machinist@large (04-22-2016)
Old 04-21-2016, 05:58 PM
Jrgunn5150's Avatar
Rudderless
I've never burned a motor on nitrous, and I've been racing for about twenty years now.
I have busted other part's lol.
bob58o (04-21-2016)
Old 04-21-2016, 06:51 PM
mckutzy mckutzy is offline
Kinda like a sneaky-pete.....
I think thats NOS brand though(holly performance).
bob58o (04-21-2016)
Old 04-21-2016, 07:37 PM
Jrgunn5150's Avatar
Rudderless
I think they discontinued that, but it was NOS brand. Compucar had one that went in a gym bag I used to used, threw dirty underwear on top of it lol.
bob58o (04-21-2016)
Old 04-22-2016, 03:55 PM
FreeRunner15 FreeRunner15 is offline
Banned
Billet rod, billet piston. Billet everything.
Better not run lean! *poof!* 02 sensors save engines.
Old 04-22-2016, 04:06 PM
Poboy kartman Poboy kartman is offline
Banned
'Speak and Spell':
And the cow says: "MOO"..the duck says "Quack"..... can anyone figure out what the Jackass says?
HINT....HINT.....^
The Following User Says Thank You to Poboy kartman For This Useful Post:
Old 04-22-2016, 05:01 PM
chancer's Avatar
chancer chancer is offline
ɔ ɥ ɐ u ɔ ǝ ɹ
Originally Posted by bob58o View Post
"Direct-port system for carbureted single cylinder engine. Includes our exclusive "PROTON" solenoid assembly,braided stainless hoses,Piranha nozzle,fuel pump, relay,microswitch, arming switch, jetting for bottle and two stainless steel bottle brackets.
Hey Don't forget the Dilithuim Crystals and be sure to get the Unobtainium head. Hard to get but well worth the investment!
Why don't you, go back to your double wide and fry something!
The Following 2 Users Say Thank You to chancer For This Useful Post:
bob58o (04-22-2016), machinist@large (04-22-2016)
Old 04-22-2016, 05:34 PM
......ohhhh.... While your at it.... You might as aswell get 3 or more of those fancy Adamantium sprocketed jackshafts, to top it all off...
You know it might come in handy one day...
  #11
Old 04-22-2016, 07:12 PM
Banned
Anyone handing out donations? i'll do it
  #12
Old 04-22-2016, 07:33 PM
bob58o's Avatar
I've soaked all parts overnight in unicorn tears. I'm good! Lol
  #13
Old 04-22-2016, 07:37 PM
Banned
Just in case, I have a couple of billet pistons laying around!
(They need to be cleaned though, they're full of East Texas horsesheet!!!!)
  #14
Old 04-22-2016, 09:24 PM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
"Adamantium Jackshaft"
Now I have to clean the Pepsi that flew out of my nose onto my computer screen.
machinist@large (04-23-2016), mckutzy (04-22-2016)
  #15
Old 04-22-2016, 10:32 PM
Yes that's correct... And at least 3 of them to be sure....
Oh by the way... That's crocodile tears and powdered unicorn horn...
Mixed Aprox..6:1 ratio... For an adiquet lubricant of impeccable performance.
The Following 2 Users Say Thank You to mckutzy For This Useful Post:
bob58o (04-22-2016), machinist@large (04-23-2016)
  #16
Old 04-23-2016, 07:47 AM
leesiel's Avatar
leesiel leesiel is offline
Yardcart 196
I mix mine @4.41:1 for peccable performance
  #17
Old 04-23-2016, 11:03 AM
Ya...dont.... hence your perfomance loss....
If that be the case...... you might aswell as just bore out the e-tube and main jet a couple of mm.... slap on another carb(for more boost... of course), take a good swig of some water meth mix(50% works but might need more experimentation) a chaser of Everclear, and to top it all off(I recall it had been 420 as of late...) A long haul bong hit of skoal....
100% Guaranteed to compensate for improper horn/tear ratio use.
The Following 3 Users Say Thank You to mckutzy For This Useful Post:
bob58o (08-22-2016), machinist@large (04-23-2016), Poboy kartman (04-23-2016)
  #18
Old 04-23-2016, 11:10 AM
chancer's Avatar
ɔ ɥ ɐ u ɔ ǝ ɹ
420 hey, Unicorns, Rainbows. and I dont use Crocodile tears, I use "Bernie" Tears.
The Following User Says Thank You to chancer For This Useful Post:
  #19
Old 04-23-2016, 11:32 AM
Banned
Thanks...now I'm craving a crabby burger!
  #20
Old 04-23-2016, 11:49 AM
machinist@large's Avatar
machinist@large machinist@large is offline
Wouldn't that come under the heading of cannibalism????? You know, a crabby guy craving a crabby sandwich???
Just a machinist looking for a home......
HTML code is On
