Old 11-26-2006, 01:39 PM
mikeandike mikeandike is offline
Default C brackets
I have another question. Will aluminum C brackets be strong enough to hold up an aluminum frame and about a 110 pound driver?
Old 11-26-2006, 01:53 PM
RobertD's Avatar
RobertD RobertD is offline
Administrator
what's the source on them?
Old 11-26-2006, 04:01 PM
source???? If you mean where thay're coming from them im making then either out of 1/4" flatstock or some big square tubing cut in half
Old 11-26-2006, 09:19 PM
RobertD's Avatar
Administrator
you've got an aluminum setup on your welding rig?
Old 11-27-2006, 06:59 PM
yup the frame is all 1 1/2" aluminum tubing. theres only a few things that are steel. so the frame by itself might weigh 5-10 pounds probably closer to 10 though the motor weighs 37 lbs dry. so around 160 pounds for me, the frame and the motor
Old 11-27-2006, 07:15 PM
RobertD's Avatar
Administrator
too awesome...
I have no idea about aluminum in regards to strength, though. maybe someone else?
Old 11-27-2006, 09:06 PM
well for those of you who dont know the other option already it is to get some 1 /14" steel tubing that'll fit inside the existing frame and bolt it on and just weld the rest onto that.
Old 11-28-2006, 02:25 PM
Lead Foot Lead Foot is offline
That thing is going to haul at that weight! Alluminum is weaker than steel but I'm not sure if its too weak for the C brakets.
Have fun,
Matt
Old 11-28-2006, 06:22 PM
i might take the chance but because my dad's friend is REALLY nice i got all that aluminum for free so if it dosnt hold up and it brakes that might not be so good... but 1/4 flat stock should be fairly strong i think...
Old 11-28-2006, 06:41 PM
RobertD's Avatar
Administrator
You're fine with 1/4" steel. That's what I used.
