  #101
Old 07-25-2011, 05:11 PM
Doc Sprocket's Avatar
You drilled what?
  #102
Old 07-25-2011, 05:19 PM
devino246's Avatar
devino246 devino246 is offline
Official DIYGK Chem Nerd
Originally Posted by toystory_4wd View Post
You drilled what?
x2
ASE Certified
  #103
Old 07-25-2011, 05:24 PM
kendelrk's Avatar
kendelrk kendelrk is offline
redneck engineer
i had no fuel flow, under the switch is a circle peice with one hole in it, it was plugged, and it only let little drips after, so i drilled out the hole bigger to let more fuel into the carb, and then flipped the washer around under the top and its running perfectly
Great, now rebuild the engine.
Be a leader not a follower, but if your going to be a follower, follow the right leader
  #104
Old 07-25-2011, 05:46 PM
redsox985's Avatar
redsox985 redsox985 is offline
Pictures? I'm confused.
  #105
Old 07-25-2011, 05:48 PM
Switch? Circle piece? Washer?
You ran a drill into your carb?!?!
  #106
Old 07-25-2011, 06:11 PM
devino246's Avatar
Im so confused.
ASE Certified
  #107
Old 07-25-2011, 08:26 PM
kendelrk's Avatar
redneck engineer
ill post picks tommarow, and no, never would do that toystory, theres a half circle plate, took that off, a little wavy washer under that, the switch turn itself, and then a peice of rubber, i drilled into the rubber peice a bigger hole, and cleaned all of it up, installed the wavy washer backwards and tada, my engine runs perfectly
  #108
Old 07-25-2011, 08:43 PM
Russ2251's Avatar
Russ2251 Russ2251 is offline
AZUSA:Powered by LAWN-BOY
Fuel valve?
Not what most of us would call a switch.
Why did you not tell tell us this valve was modified to begin with?
https://www.youtube.com/watch?v=c4jch0puM1A
  #109
Old 07-25-2011, 09:00 PM
kendelrk's Avatar
redneck engineer
well i guess im a bit bad with words, yes the fuel valve, and it wasnt, today is the first time it was ever apart
edit: ill take pics tommarow, but heres a vid of me riding it today, taken by my little brother and his friend
  #110
Old 07-25-2011, 10:38 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
ive been talking to him bout this,
the fuel petcock is what he had to drill out. theres a washer with 4 holes in it and its CHEAP. made terribly. so that the fuel was barely going through the valve.
the reason why it ran for a little fine, then had to be choked, is because over time the fuel would seep into the bowl through the shut off petcock, and once it was burned out of the bowl, it was barely dripping, so not enough to keep the engine running.
long story short- the fuel valve was defective and not letting enough gas into the bowl.
  #111
Old 07-26-2011, 03:50 AM
Ahh. Thanks for the clarification, Blue.
