Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 09-08-2010, 05:44 PM
dennishagan dennishagan is offline
Junior Member
Default Comet Torq converter
I have a red Dirt Dog.Looks like a Jeep.It has a Comet
Torq-A-verter Asymmetric.C.A.T.99.It has three holes in it on one side that are numbered 1,2,3.It looks like it is set on number one.I can see a pin or something in it.Two and three are empty holes.Can i adjust it and how do I do so.Also, could you tell me what this adjustment dose.
Old 09-08-2010, 06:08 PM
r97's Avatar
r97 r97 is offline
Measure twice cut once
the "pin" is actually a spring, moving the spring into the other holes will in-crease the amount of time it takes the tc to shift up, this is good for climbing hills.
Old 09-08-2010, 11:08 PM
Blazkowiez's Avatar
Blazkowiez Blazkowiez is offline
Kart Aficionado
Moving into the higher holes will decrease tension and force the clutch to engage faster and lead to a potentially dangerous situation should your kart be pointed towards your neighbor's new car...
gokartrepair.com. Family owned and operated in Houston for 40 years. Parts-Service-Advice
The Following User Says Thank You to Blazkowiez For This Useful Post:
dennishagan (09-09-2010)
Old 09-09-2010, 01:53 PM
Junior Member
Thanks for the reply,but how do I adjust it.I have pretty good trails but there are a few hills I have trouble with.If I adjust it to the two or three will it climb better??It is a very strong cart,but those dang hills slow me down.Thanks..
Old 09-09-2010, 02:03 PM
mike75925's Avatar
mike75925 mike75925 is offline
thinker and tinkerer
as per blaz's reply, no. number one has the most tension. for climbing the hills you want to stay in a ratio that will get you there. at least, that's what i understand from blaz.
deo non fortuna
The Following User Says Thank You to mike75925 For This Useful Post:
Blazkowiez (09-09-2010)
Old 09-09-2010, 04:01 PM
Blazkowiez's Avatar
Kart Aficionado
Mike, thank you for making sense.
Gearing and Engagement can occasionally accomplish similar results are not the same thing, if you want to climb a hill you need to change your ratio for more torque, not have your clutch catch earlier.
  #7
Old 09-09-2010, 04:19 PM
mike75925's Avatar
that being said, by having your clutch engage later, your engine will be at a higher power rating when it does engage. think of a stall convertor in an auto tranny.
deo non fortuna
  #8
Old 09-09-2010, 07:45 PM
r97's Avatar
r97 r97 is offline
Quote:
Closed Thread
