Reply
Old 02-10-2020, 08:09 AM
RandomK RandomK is offline
Junior Member
Default HELP I got a go kart with 169cc engine
I got a go kart with a 169cc suburu engine and I would like to change it for a predator 212cc. Is it the same build plate size so I can just bolt it in and not have to change anything?
Old 02-10-2020, 09:03 AM
mckutzy mckutzy is offline
For the most part it is...
Old 02-10-2020, 09:24 AM
itsid's Avatar
itsid itsid is offline
keep the robin subaru on a shelf as a backup engine.. it'll outlive several predators
(and with 6.5horses it's not even less powerfull than a stock predator)
there's just no aftermarket modding parts for one really...
but left stock, it's about as good as an engine can be;
So yeah, if you want it to be reliable, keep the subaru as a backup just in case
Old 02-10-2020, 11:45 AM
Junior Member
Okay thanks... but do you know if the mounting holes on the predator are the same as the suburu
Old 02-10-2020, 11:53 AM
Budget GoKart's Avatar
Budget GoKart Budget GoKart is offline
Aka a kenbar
Yes they are almost all the same for 212 196 and most lower cc engines
I gotta fix my flathead collection
Old 02-10-2020, 12:12 PM
Junior Member
What should I get to make this go really fast. 18inch wheels and a 196cc suburu and a tourque converter go kart? What gear ratio for top speed?
  #7
Old 02-10-2020, 12:52 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
What gearing does it have? What top speed do you want?
Moreover:
We need pics, and a detailed request to be able to help you.
Currently Flathead-Crazed
  #8
Old 02-10-2020, 03:37 PM
Junior Member
How much do you think this go kart is worth
---------- Post added at 03:37 PM ---------- Previous post was at 03:36 PM ----------
https://photos.app.goo.gl/YBJPMpBEEG1y3YKdA
---------- Post added at 03:37 PM ---------- Previous post was at 03:37 PM ----------
https://photos.app.goo.gl/hkPrKoRhpjNpEiweA
  #9
Old 02-10-2020, 04:15 PM
Aka a kenbar
A clapped out manco red fox? Not much at all
  #10
Old 02-10-2020, 04:18 PM
Junior Member
Like how much it runs and drives, how much would you pay for it
  #11
Old 02-10-2020, 04:19 PM
Aka a kenbar
Id pay at most 180$ with a seat and some tire shine 200$ or 220$
  #12
Old 02-10-2020, 04:24 PM
Junior Member
I'd pay 200$- for it... but it needs a gas tank. Is that good?
What speed do you think I would get outta this
  #13
Old 02-10-2020, 04:26 PM
Smerft85 Smerft85 is offline
I'd build it and thrash it. You'd likely put more $ into it to fix it enough to get half your money back. I know my dingo of similar build with a 212 clone does over 40mph with only a governor delete, I don't remember it's ratio off hand but it's running 18" rears too.
  #14
Old 02-10-2020, 04:32 PM
Aka a kenbar
To me worth 180$ no more without a tank
  #15
Old 02-10-2020, 05:12 PM
Junior Member
So I should buy it for 200$ I wanna put lights on it and stuf
  #16
Old 02-10-2020, 05:19 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
Lights require a battery that you will pull off and charge or an engine with a charging system. I wouldn't pay more than 180 for that go kart. That's if the subaru will run off starter fluid.
If it's not scary you're not going fast enough
  #17
Old 02-10-2020, 05:30 PM
Junior Member
Ya the engine starts with starting fluid and all tires are good and all tires are good
  #18
Old 02-10-2020, 05:53 PM
Offer $150 and see what happens.
  #19
Old 02-10-2020, 06:38 PM
Junior Member
Okay thanks
---------- Post added at 06:38 PM ---------- Previous post was at 06:04 PM ----------
He has it posted for 300. Lowest he can go is 200. And it has a tourque converter. The sticker says it's a red fox LXT and its extended
  #20
Old 02-10-2020, 07:06 PM
Quote:
Originally Posted by RandomK View Post
Okay thanks
Extended as in a stretched frame? Ultimately it's up to you, I think $200 in that condition is quite a stretch, entire frame could be crooked like the stretched dingo I picked up, and have since parted ways with. Without knowing the owners fabrication skills $150 is probably a high offer.
Reply
