Closed Thread
Old 01-12-2018, 04:34 PM
mindymogul's Avatar
mindymogul mindymogul is offline
Mistress of Destruction
Default Never doubt senile people. You'd be surprised.
Carb #1 was off a snowblower that sat for 3 years without even being glanced at and sat behind a shed through all elements. There was no gas in it, it was covered (mostly) and the rest of it was relatively clean. Kinda self explanatory why it didn't run. (Freebie Cumseh OHSK130)
Carb #2 however sat since 1996 in a hoard pile until it was hauled out beside the road where I adopted it and brought it home. The tank had gas and was directly connected to the carb so 22yo fuel just rotting away. It started 1st pull then immediately blew it's guts out the carb. (Freebie Cumseh HM100)
Both sat in a combo of 3/4 cup white Vinegar, 1/2c ZEP 505, and 3/4 cup apple vinegar. No brushes, ultrasonic tanks, or any thing else other than a hairdryer was used to clean them. Just 3hrs in that solution some guy at a nursing home told me and BAM. Both start and run 1st pull every time.
Listen to your elders kids. You just might learn something...
Official Taco Tester~
The Following 3 Users Say Thank You to mindymogul For This Useful Post:
Joe-405 (01-12-2018), KingCobra (01-13-2018), qtband (01-13-2018)
Old 01-13-2018, 11:31 AM
KingCobra's Avatar
KingCobra KingCobra is offline
TROLL CRUSHER INC.
And what have we learned from this experience? That no matter how long a carb has sat, it is always wise to drop that one bolt retainer, drop the bowl and just clean it out and flush the gas tank and fuel line while your at it. I have no idea how that junk get's down in there( ok, I do ) but the bowl was designed to be a 'catch all' of trash coming from the gas tank. BTW, I use gas filters between the gas tank and carb now.
Even though I walk through the darkest valley, I will fear no TROLL...
Old 01-13-2018, 04:57 PM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
Quote:
Thank you so much.
I do not recall Congressman.
Old 01-14-2018, 02:40 AM
bob58o's Avatar
bob58o bob58o is offline
Assistant to the Manager
Sediment bowls are designed to be the catch can.
https://www.everestpartssupplies.com...-sediment-bowl
There are two types of people. Those who can extrapolate data
The Following 2 Users Say Thank You to bob58o For This Useful Post:
ezcome-ezgo (01-15-2018), Nosandwich (01-14-2018)
Closed Thread
