Old 12-28-2019, 05:49 PM
jmaack jmaack is online now
Default letgo score.
finally found what I was looking for. the minibike is just extra.
Old 12-28-2019, 05:50 PM
more
Old 12-28-2019, 05:51 PM
bike
Old 12-28-2019, 05:52 PM
I got both for 70$ With a questionable engine that he says runs.
Dont really want the bike. This cart will be perfect for my vintage looking build. Any idea what model it is? Streaker s365 maybe????
Check out the cobbled up crossover steering and other homemade goodness. Anyone know where best place to buy parts would be?
Old 12-28-2019, 06:08 PM
Budget GoKart's Avatar
Aka a kenbar
I litterally just got home from buying a manco 405 from letgo
Old 12-28-2019, 07:45 PM
BigWes's Avatar
BigWes BigWes is offline
Looks Ken-Bar to me. You got a good deal. Well done!
Old 12-28-2019, 09:12 PM
MrC. MrC. is offline
Congratulations, I just picked up 2 manco's on letgo last week.
MrC.
Old 12-29-2019, 12:45 AM
Smerft85 Smerft85 is offline
Where you located? May be interested in the bike.
The Following User Says Thank You to Smerft85 For This Useful Post:
jmaack (12-29-2019)
Old 12-29-2019, 07:47 AM
The mix of square and round tubing makes me think it's a Carter Bros. kart, but I don't really know. The Honda clone on it looks pretty clean!
The minibike looks like a Baja Warrior. Pretty big bike.
Currently Flathead-Crazed
jmaack (12-29-2019)
Old 12-29-2019, 05:48 PM
Birmingham, Alabama
I decided to build the bike. My wife said she thinks it would be more fun. Plus there are some issues with the cart that were repaired in ways I dont care for. Front driverside axle/spindle mount was cracked and welded zoom in to see. Underneath the engine they welded allthread to the bottom on one side I can only assume for a crack. Its solid as i was jumping prety hard on it all 190 pounds of myself but i just cant put much $ in to it with these issues.
That being said. The cart is on letgo and Craigs for cheap.
---------- Post added at 06:36 PM ---------- Previous post was at 06:35 PM ----------
Coleman ct200u-ex is what the bike is.
One day I am going to build another and throw on a cleaner vintage cart.
---------- Post added at 06:48 PM ---------- Previous post was at 06:36 PM ----------
On way from amazon for friday delivery.
Front/ rear bearings, torque converter, new chain, new throttle and brake cables, new throttle and brake levers and grip, rear chain tensioners yada yada.
Next thing is i am missing the bushings for the rear end.
The Following User Says Thank You to jmaack For This Useful Post:
JTSpeedDemon (12-29-2019)
  #11
Old 12-29-2019, 11:42 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
With pipe frames one way to fix em is an insert that goes under the two pieces being welded, did it for a friend's kart after he broke the same piece off the front.
The Following User Says Thank You to Dingocat For This Useful Post:
jmaack (12-30-2019)
  #12
Old 12-30-2019, 08:49 AM
Aka a kenbar
I have a manco 405 in almost mint condition id trade for your carter i live in indiana but sadly nothing to transport stuff
jmaack (12-30-2019)
  #13
Old 12-30-2019, 11:09 AM
I like to drill a hole in both halves that broke,side a smaller pipe inside the broken two piece, weld the gap and plug weld where I drilled.
MrC.
The Following User Says Thank You to MrC. For This Useful Post:
jmaack (12-30-2019)
  #14
Old 12-30-2019, 04:20 PM
FWIW if someone on here wants the cart and they are local to me they can have it. Birmingham alabama.
---------- Post added at 05:20 PM ---------- Previous post was at 05:20 PM ----------
if you were close i would totally do it. I am only 3 miles from i65 hah
