Reply
Old 10-12-2019, 04:00 PM
rjmorel rjmorel is offline
Junior Member
Default HF Predator 301 flywheel for lighting
I have a Harbor Freight predator 301cc engine I'm putting in a motorcycle and need a 3 magnet flywheel to generate power for the lights. Where can I get one ? Or should I just get a HF starter kit and throw most of it away. I've have a 212 in it now but the flywheels and charging coils are different size. thanks rj
Old 10-12-2019, 06:23 PM
Kartorbust's Avatar
Kartorbust Kartorbust is offline
I'm not sure that a GX240/270 flywheel will fit on there for a stator. The only engine besides the 670 that has a charging stator, is the 420 and that's only 3amps.
The crank shaft might have a different taper for the flywheel on the 301 than say a Honda GX240/270 engine. I haven't found anything online to help out on this unfortunately. You may just have to work with either a battery and charge it often, or get an engine that has a charging stator.
Reply
