Go Back   DIY Go Kart Forum > Building Plans And Advice > Mini Bikes, Trikes, and Choppers
Reply
Old 08-23-2019, 11:58 AM
batman3n1 batman3n1 is offline
Junior Member
Default Need Help
I need a solution that will keep the crankshaft from spinning when torquing the flywheel. I've heard where some have drilled holes in a TC keyed driver backplate, but can't find anywhere to buy just that part. I don't want to shove rope down the spark plug hole to keep the piston from turning either. I want something thats keyed that I can bolt to the block. Any suggestions? Anybody got a spare driver gear backplate they want to sell? Thanks
Old 08-23-2019, 04:09 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
Ugga Dugga
The Following User Says Thank You to bob58o For This Useful Post:
itsid (08-24-2019)
Old 08-23-2019, 05:47 PM
mckutzy mckutzy is offline
Heres an idea....
https://www.ezbore.net/Crank-Lock-p/ept99049.htm
But Ive seen a few others...
A Sprocket with a key that big enough to fit the PTO equipment mounting outer holes.
A hub or sprocket with a key thats welded to a long bar to hold onto... as to wrench with the other hand...
The Following User Says Thank You to mckutzy For This Useful Post:
batman3n1 (08-26-2019)
Old 08-24-2019, 12:17 AM
itsid's Avatar
itsid itsid is offline
the fixed sheave of a TC driver can be bought seperately from mfgsupply.com
BUT only as an original Comet part for all I know..
and it's almost cheaper to buy a full TAvKit on ebay from china
But you can buy 3/4" keyed type B or C sprockets in nearly any kart shop.
A piece of chain bolted to some barstock can nicely wrap around such sprocket as a makeshift handle
(IDK what chain size those oil filter wrenches use but if it by chance is #35 or such... those might come in handy too)
The Following 2 Users Say Thank You to itsid For This Useful Post:
batman3n1 (08-26-2019), mckutzy (08-24-2019)
Old 08-24-2019, 09:20 AM
Oh ya forgot about the chain wrap type.. could do...
Old 08-26-2019, 11:17 AM
Junior Member
Quote:
Originally Posted by mckutzy View Post
Heres an idea....
That’s the ticket!! Thanks!
  #7
Old 08-26-2019, 11:20 AM
If your handy.. could build one yourself..
batman3n1 (09-02-2019)
Reply
