Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
  #61
Old 09-29-2019, 12:34 AM
22x11?
  #62
Old 09-29-2019, 12:46 PM
Dingocat's Avatar
Dingocat Dingocat is online now
Broke
Quote:
Originally Posted by mrmonk7663 View Post
22x11?
2112
Current Manco hoarder
The Following User Says Thank You to Dingocat For This Useful Post:
Mrmonk7663 (09-29-2019)
  #63
Old 10-01-2019, 06:34 PM
Dingocat's Avatar
Broke
Got my tc in today, 1 inch 30 series to go on the briggs, need the sidecover off the other engine at the least or going to do a crank swap. The snowblower engine only has 3 bolt holes for mounting it.
  #64
Old 10-02-2019, 05:32 PM
Dingocat's Avatar
Broke
Got axle bearings, need to bolt the hangers on and get my hubs fixed, move the sprocket hub ~1", modify my engine mount, get eithor the crank swapped or the sidecover.
  #65
Old 10-03-2019, 08:39 PM
Dingocat's Avatar
Broke
Got my torque converter mocked up. Need the crank off the other engine because this one looks cleaner and has less rust/corrosion.
  #66
Old 10-12-2019, 01:25 PM
Dingocat's Avatar
Broke
Off the jack! For now. Believe my wheel hub is bent.
  #67
Old 10-12-2019, 06:55 PM
Dingocat's Avatar
Broke
Hub is less bent than I thought, just a tad off. Should be fine. Going to be mostly offroad.
  #68
Old 10-12-2019, 10:18 PM
Dingocat's Avatar
Broke
Got most of the way through swapping the side covers before I found out that the other cover was too wide.
Can I run the tc with 3/4 bolts? Doesn't havevthe 4th hole.
  #69
Old 10-12-2019, 11:12 PM
Smerft85 Smerft85 is online now
Looking good! I don't see why three bolts wouldn't hold up on the t/c. Btw, I just picked up another small frame dingo like this one, old Tecumseh 6hp, still turns over but someone messed up the choke and throttle stuff, so no idea if it runs. Appears to be mostly original but missing the roll cage, $80!
  #70
Old 10-12-2019, 11:14 PM
Dingocat's Avatar
Broke
Quote:
Getting all the good deals! As soon as this is running I can clean up a good bit of my workspace and get it to be somewhat reasonable. Too many karts and parts and not enough space.
Mrmonk7663 (10-13-2019)
  #71
Old 10-14-2019, 07:12 PM
Dingocat's Avatar
Broke
Thinking of going back to the original plan of gx160 on the dingo for now, need to get parts for the 8 and the subaru can go back on the other kart.
landuse (10-15-2019)
  #72
Old 10-16-2019, 08:50 PM
Dingocat's Avatar
Broke
Getting there. Need to flip the left axle bearing, move my sprocket back, and get my brake together.
  #73
Old 10-17-2019, 06:54 AM
JTSpeedDemon's Avatar
Currently flathead-crazed
On my local Craigslist right now there's the same kind of Dingo, without any cage. They're askin' $550 for a fully running Predator 212 Dingo. Too high for me, but it is my favorite model of Dingo. It's also got a few(if not all) of the original hubcaps!
I would love to get it to bang around on, but I don't have that kinda money, and my parents want me to clear out 2 projects before I get another one.
Local Bird Engineering Nut
  #74
Old 10-17-2019, 09:39 AM
Dingocat's Avatar
Broke
I have a snowblower and 6 karts, I can't get any more for a good while. Need to sell some.
---------- Post added at 10:39 AM ---------- Previous post was at 10:37 AM ----------
I have the old "cage" sitting in the attic, for when I'm done with the rest.
  #75
Old 10-17-2019, 10:47 AM
I've got 2 and only need 1.....
  #76
Old 10-17-2019, 09:54 PM
Dingocat's Avatar
Broke
Moved my hub back, put a chain on, tightened the tc nut, amd spent time working on my truck. I sanded and painted where I had primed (corners of the bed), and painted them. Hard to notice a difference from far away.
  #77
Old 10-29-2019, 02:55 PM
Dingocat's Avatar
Broke
She lives again! Have a bent hub or axle.
  #78
Old 10-29-2019, 03:22 PM
Nice!
Are you going to wire wheel those front wheels? They look a bit rusty.
Also, how many teeth on that sprocket?
  #79
Old 10-29-2019, 07:06 PM
Dingocat's Avatar
Broke
Nice!
Original paint on the fronts. The gold on the cast wheels. I'll clean them eventually. Before you say anything about my gear ratio, it's 9 to 54 and it's way too high. It's what I have on me at the moment but will probably get 8 to 60 if possible.
JTSpeedDemon (10-30-2019)
  #80
Old 10-30-2019, 12:24 AM
Awesome. Good to see it up and inning. 60/8 feels really good. I have it on a kart with 20” wheels.
Reply
