Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Reply
  #41
Old 08-11-2019, 09:36 AM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
Quote:
Originally Posted by Smerft85 View Post
I didn't bother with primer, but learned a few tricks when I did paint and body. After paint it goes together super fast, and I did figure out the throttle pedal at least, so If you need pictures when you put it together I can post some.
I'm going to put a coat. But after I paint it I need parts, when I got it both bearings were seized. And I should be able to figure out the throttle, thanks though.
If it's not scary you're not going fast enough
  #42
Old 08-19-2019, 10:11 PM
Dingocat's Avatar
Broke
Sorry for sideways pic..... Click image for larger version
ID:	111091 only pic I've got from today. Before painting the seat and area around it. had to take it down so we could pull my truck into the barn. Click image for larger version
ID:	111092 Put it on jacks because of leaky brakes, found holes in the frame. Time to go car shopping.
  #43
Old 08-20-2019, 01:42 AM
Progress
  #44
Old 08-20-2019, 06:34 AM
Dingocat's Avatar
Broke
And setbacks. https://youtu.be/2WtTxaAjhDo
  #45
Old 08-20-2019, 12:30 PM
That frame hole is nasty!!
  #46
Old 08-20-2019, 05:25 PM
Dingocat's Avatar
Broke
More than one. My dad is thinking about fixing it but at the same time my mom wants it out of the way/gone.
  #47
Old 08-20-2019, 05:49 PM
Dingocat's Avatar
Broke
Pic. Primer from yesterday. More to do but sand first.
  #48
Old 08-20-2019, 06:48 PM
Smerft85 Smerft85 is offline
Dingo is starting to look good, that Toyota on the other hand I don't know that "repair" would be the proper term, perhaps replace the frame?
  #49
Old 08-20-2019, 08:24 PM
Dingocat's Avatar
Broke
He plans to chop it back to solid metal and get a new piece to wel d in, with propper bracing. Maybe take a trip to a junkyard and see if we coould get a frame cheap.
  #50
Old 09-03-2019, 10:04 PM
Dingocat's Avatar
Broke
Got some stuff done. Most of the remaining frame is primed. And the truck is welded. Clean it up a bit, paint where we welded and put in new brale lines and it can all go back together.
The Following User Says Thank You to Dingocat For This Useful Post:
Hellion (10-31-2019)
  #51
Old 09-04-2019, 01:35 AM
Awesome. Glad the truck is fixed. Kart looks good. I’m still chugging away at my projects as well.
The Following User Says Thank You to Mrmonk7663 For This Useful Post:
Dingocat (09-04-2019)
  #52
Old 09-18-2019, 09:09 PM
Dingocat's Avatar
Broke
Progress.
The Following 2 Users Say Thank You to Dingocat For This Useful Post:
Hellion (10-31-2019), Mrmonk7663 (09-19-2019)
  #53
Old 09-19-2019, 08:25 PM
Dingocat's Avatar
Broke
Got lug nuts for the wheel hubs. Then found out my dad had some stashed away. And also ran around town looking for wheel studs. Going to try the small engine repair place that my friend works at.
  #54
Old 09-20-2019, 02:06 AM
landuse's Avatar
landuse landuse is offline
Looking good!
  #55
Old 09-20-2019, 11:50 AM
Dingocat's Avatar
Broke
Got another Briggs. 8 horse. Tapered shaft. Going to probably swap the crank from my other briggs into it.
  #56
Old 09-20-2019, 12:02 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Is the new one the I/C one?
I would love to get my hands on a sleeved flathead.
Currently Flathead-Crazed
  #57
Old 09-20-2019, 12:36 PM
Dingocat's Avatar
Broke
Not my i/c. Friend's. I would have gotten it but needed the other for the dingo.
---------- Post added at 01:36 PM ---------- Previous post was at 01:34 PM ----------
My dad did get a newer 5 horse off his friend for free. Sat, had a stuck valve, friend fixxed the valve but says it pops alot at higher rpm.
  #58
Old 09-20-2019, 02:07 PM
So your new flathead is the black one in the corner?
Don't keep us guessing, 'cat!
  #59
Old 09-20-2019, 10:18 PM
Dingocat's Avatar
Broke
Yes. Black one. Has the airfilter/intake that I need. The muffler is toast. End piece falls off.
JTSpeedDemon (09-21-2019)
  #60
Old 09-28-2019, 11:07 AM
Dingocat's Avatar
Broke
Got a new tube put in. These tires look awesome
Reply
