Closed Thread
Old 09-19-2018, 07:16 PM
SquidBonez's Avatar
SquidBonez SquidBonez is offline
Default What's your top speed?
What's the fastest you've gone in your kart/minibike? Assuming 4-stroke karts/bikes, but 2-stroke welcome too. Currently got the old 5.5 HP Manco Dingo up to 30 on grass.
"You know I had to do it to 'em."
Old 09-19-2018, 07:27 PM
Tpdingo Tpdingo is online now
32 on a 6.5HP Dingo 286. Well I did 30, my friend went ballistic and did a crazy stunt getting up to 32, and nearly killed himself in the process. My run was grass to get up to speed and ended on pavement. His run was all pavement.
Measured with DigiHUD and a ziptied phone on the steering wheel.
Give a wrench long enough and WD-40, and I can remove the world's rusty bolts.
Old 09-19-2018, 08:15 PM
2SlickNick's Avatar
2SlickNick 2SlickNick is offline
American Minibikes @ FB
65 mph on my Baja warrior drag bike.
https://www.youtube.com/user/dirtyinaz
Old 09-19-2018, 08:20 PM
Panhead5496's Avatar
Panhead5496 Panhead5496 is offline
Quote:
I got my Baja Warrior up to 45mph one time and scared myself lol! Too fast on stock tires.
Got my YerfDog up to 37 mph, and it was almost as scary as the Baja
I used a iPhone app that saved top speed for each run so I didn't have to worry about looking at it while driving lol.
Old 09-19-2018, 08:28 PM
2SlickNick's Avatar
Watch around the 3 min time... I did 65 with that set up. I am trying currently running 60mph in the 1/8 mile.
---------- Post added at 06:28 PM ---------- Previous post was at 06:27 PM ----------
Def scary on stock tires... and plenty fast of a yerf dog.
The Following User Says Thank You to 2SlickNick For This Useful Post:
Panhead5496 (09-26-2018)
Old 09-19-2018, 08:35 PM
tgus3's Avatar
tgus3 tgus3 is offline
a member
I did 48.8 downhill(a little bit ) on concrete in my go kart. I also had a app that saved my top speed.
Only know you love it when you let it go..
  #7
Old 09-19-2018, 08:55 PM
bob58o's Avatar
bob58o bob58o is offline
Sick, Tired, and in Debt
This vid shows 52mph uphill on my trailmaster ts500, but I've done 55 on it.
My El Lobo minibike will go much faster, but haven't had the real estate to hold WOT for long enough (plus it is currently geared for way too much bottom end, scary when the front end comes up that easily.)
  #8
Old 09-19-2018, 08:59 PM
anickode's Avatar
anickode anickode is offline
My little home built yard kart (not very heavy) will squeak out 43mph on a long flat straight if I've got the tires aired up nice and stiff. 37mph if they're aired down a bit, which is how I usually keep them. That's with a Briggs Intek 190 ohv running no governor, a homemade long 3 step header, and a jetted GX200 carb with a homemade adapter and 3" runner for a little extra low end. And 200 lbs of driver.
The rat wagon will hit 27 with a 196 clone, gov delete, jet, and exhaust, but the mule drive eats up a ton of power. Which is ok. With its long skinny stance, solid front tires, janky steering, and a jackshaft brake, I don't really even like going 27 on it.
The drift trike (almost finished) goes... I dunno how fast it would go. It's sort of a hard thing to top out. Anything above 20mph on the GPS, and it gets pretty darn sketchy, especially with no rear brakes.
"Well that would be a bomb."
  #9
Old 09-19-2018, 09:20 PM
SquidBonez's Avatar
The inspiration for this thread was this video here:
Apparently this is a 9.5 HP predator 212, on what I assume are 11/11.5 inch rear tires with a 58T sprocket and a 14T sprocket. They said they managed to get 53 MPH out of it. I used one of those online calculators, and with their setup that shouldn't be possible. I mean, I know they have the governor removed, but even at 6000 RPM they wouldn't be doing 53 on flat ground (plus, I've never seen a 212 push out that kind of RPM unless it was heavily modified, which this one is not).
Sorry if a bit off topic, but I wasn't sure if this deserved its own thread.
  #10
Old 09-19-2018, 09:25 PM
bob58o's Avatar
With 12" Tires, and 6200 RPM, 58 :14 would give about 53mph.
Where does it say 53? I think I saw 44mph?????
  #11
Old 09-19-2018, 09:30 PM
SquidBonez's Avatar
I may not know the size of the back tires, but once again 6200 RPM out of a mostly stock predator other than governor removal and some power mods seems unlikely. I thought stock ungoverned 212s maxed at like 5800 RPM or something similar.
  #12
Old 09-19-2018, 09:31 PM
bob58o's Avatar
So where did you get 53?
5600 RPM with 11" tires and 58 :14 gives 44mph, which is the highest I saw.
  #13
Old 09-19-2018, 09:35 PM
SquidBonez's Avatar
In the description. They claimed that the kart has done a confirmed 53 MPH on flat asphalt.
The Following User Says Thank You to SquidBonez For This Useful Post:
bob58o (09-20-2018)
  #14
Old 09-19-2018, 09:42 PM
bob58o's Avatar
Cars' speedometers are set fast. If your car shows 52mph, then you are probably doing 50 mph. GPS speedos are probably more accurate than your car's speedo.
Plus I don't believe what I can't see. (Oh me of little faith.) The video shows 44mph. So top speed is 44 as far as I'm concerned.
My bank statement shows $23 in my account, but I have a confirmed $457,754 in there.
The Following User Says Thank You to bob58o For This Useful Post:
  #15
Old 09-19-2018, 10:25 PM
SquidBonez's Avatar
Fair enough.
  #16
Old 09-20-2018, 09:09 AM
Jsnscott Jsnscott is offline
Junior Member
My buggy is geared for the woods Riding/hill climbing. 420 stock predator series 40 clutches top speed 22mph. Putting around 8mph.
My mini bike 296cc Honda top speed 64mph.
  #17
Old 09-20-2018, 02:49 PM
Joe-405's Avatar
Joe-405 Joe-405 is online now
2018 Buildoff Winner ! 😎😎
My go kart I just built is geared for 175+mph. And a 11 second 1/4 mile.
  #18
Old 09-20-2018, 04:56 PM
tgus3's Avatar
a member
id love to see you take it there
  #19
Old 09-21-2018, 12:40 PM
KartFab's Avatar
KartFab KartFab is offline
65 mph on a mini bike on a rutted dirt road, felt like i was going to crash sometimes my feet and hands were the only things holding me to the bike as it is a hard tail bike. was really dumb. I do not reccomend.
50 on a go kart. Felt like the go kart was going to crash the front tires were wobbling all over the place
seems like anything north of 40 is pretty dangerous. There are plenty of pictures of people on the various facebook groups people are on (cough: mini bike nation) that were going 60-75 mph and wrecked HARD. No helmet, and had serious head injuries and road rash. I dont know if they lost any iq points though. If you are dumb enough to do that stuff without the right gear you may end up dead. Its really sad, but does happen.
Those guys in detroit end up 80-90 mph on theirs. Some have wrecked pretty hard.
Free Go Kart Plans https://kartfab.com Go Kart Videos https://www.youtube.com/c/KartFab
The Following 2 Users Say Thank You to KartFab For This Useful Post:
Panhead5496 (09-26-2018), Randy H (09-22-2018)
  #20
Old 09-21-2018, 02:01 PM
BRSleeper BRSleeper is offline
Junior Member
Default 38
38 on black top, Dingo 301cc with turf savers.
Closed Thread
