Old 12-25-2019, 08:20 PM
Walter Keller Walter Keller is offline
Default Lawn Boy vert to horizontal mods
Anyone here mod a vertical shaft Lawn Boy engine for use as a horizontal shaft ? I've seen the couple examples on Youtube from a few years back - looking at doing the needed mods for a minibike build I'm working on.
Old 12-25-2019, 09:20 PM
Budget GoKart's Avatar
Aka a kenbar
Better to just look for a old side shaft engine laying around a lawn boy is going to be unpractical
Old 12-25-2019, 10:09 PM
Kartorbust's Avatar
Its difficult to do. The easier way to do it is to get a horizontal shaft engine. If you want to keep this engine, you'll need a right angle gearbox.
Old 12-25-2019, 10:37 PM
Dingocat's Avatar
Dingocat Dingocat is offline
Broke
Alot of the lawnboys are two strokes. Shouldn't it make it easier? Even though impractical. I agree. It's great to use what you got lying around but at a certain point it isn't worth it.
Old 12-26-2019, 05:02 AM
itsid's Avatar
itsid itsid is offline
a two stroke is rather easy to convert;
you need to rotate the carb and fab a mount and that's essentially it already.
Old 12-26-2019, 06:20 AM
rushking19's Avatar
rushking19 rushking19 is offline
Yes a guy named russ and a few other people have you eill.need a custom engine plate made up and you will need to get the shaft on the crankshaft cut down to fit a normal clutch
It's Fast ,But Needs One More Cylinder
Old 12-26-2019, 07:11 AM
If it's long enough. All the mowers I've seen seem to have short PTOs, but IDK.
I once wanted to convert a 149cc Lawn Boy 4 stroke we had to a go kart, but then I realized it would be a lot of trouble. So OP, is it a 2 or 4 stroke?
Currently Flathead-Crazed
Old 12-26-2019, 08:06 AM
rushking19's Avatar
Yeah if it's the 2 stroke go ahead, mostly if it's a duraforce motor
Old 12-29-2019, 01:58 AM
landuse's Avatar
landuse landuse is offline
Check out Russ2251 builds
Old 12-30-2019, 05:33 AM
rushking19's Avatar
Here's one of my favorite duraforce builds it's not only converting it from vertical to horizontal it's also modding it for more power too different carb a Tillotson head gasket mod too reed valve mods to make it have even more hp then 6.5 russ helped with this build and they estimate around 9 to 10 hp with all the mods
http://www.diygokarts.com/vb/showthread.php?t=1541
---------- Post added at 07:32 AM ---------- Previous post was at 07:31 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=1682
---------- Post added at 07:32 AM ---------- Previous post was at 07:32 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=1732
---------- Post added at 07:33 AM ---------- Previous post was at 07:32 AM ----------
http://www.diygokarts.com/vb/showthread.php?t=2399
Video of it running
https://youtu.be/1ETJey1MQGQ
