Closed Thread
Old 12-04-2017, 12:00 PM
Joshua rice Joshua rice is offline
Junior Member
Default Briggs intek tiller to go cart govener help
Hello all , I took a Briggs intek off of a Craftsman tiller to put on a go kart , how do I hook all the governor and all that up , thanks
Old 12-04-2017, 03:14 PM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
The "governor and all that" is already hooked up. If you don't post pics....good luck with ANY help.
Old 12-04-2017, 04:13 PM
Dustin2017 Dustin2017 is offline
SPP_MN
Pictures of what you have is a big help
Old 12-04-2017, 05:00 PM
mckutzy mckutzy is offline
Yes Pics will help alot...
Also a bigger question is... Does it have a useable shaft for a TC or clutch...????
Old 01-03-2018, 02:16 AM
Leobeel Leobeel is offline
Junior Member
I got mine off craftsman 17” tiller. I completely removed throttle arm from setup. Scrap box. From there I opened up crankcase and removed governor and governor tab and closed it back up. This left a governor arm connected by factory rod to the carb. I hooked my throttle cable to governor arm, while taking a new spring hooking it through one of many holes on arm to empty hole on engine for immediate recovery to idle from Wide open. Quick response, no resistance, exactly what been looking for for months and just figured out what I should do.. pictures to follow tomorrow
Closed Thread
