Closed Thread
Old 10-02-2017, 08:16 PM
cls02161987 cls02161987 is offline
Junior Member
Default Oil expander ring
Does it matter which direction the oil expander ends face up or down?
Old 10-02-2017, 09:32 PM
mckutzy mckutzy is offline
What engine??? need much more info......
Old 10-03-2017, 12:35 AM
Chuck1 Chuck1 is offline
Junior Member
Hi
Oil ring?
All 4 stroke engines l have worked on have 3 peace oil rings 1expander and 2 wipers
Place expander in grove do not over lap ends then place wiper 1 each. In grove over the small space at top and bottom of expander place gap of wipers for and aft of expander gap
Old 10-03-2017, 12:42 AM
Dustin2017 Dustin2017 is offline
SPP_MN
If there is no directions and there is markings on the wiper rings I always put the markings up
Old 10-03-2017, 05:19 AM
Junior Member
150 gy6. I got both compression ring facing up. Both have the letter A . I see ppl saying make sure the ends on the oil ring face up and then some say down. I didn't think it mattered. Is there a right or wrong way with the oil ring as long as the ends but up and don't overlap?And would the chrome ring be the top compression ring? I didn't get any directions with the rings.
Old 10-03-2017, 06:51 AM
itsid's Avatar
itsid itsid is online now
I think it's easiest with a pic:
Click image for larger version
The Following 2 Users Say Thank You to itsid For This Useful Post:
cls02161987 (10-03-2017), ezcome-ezgo (10-03-2017)
  #7
Old 10-07-2017, 06:54 AM
Junior Member
Hi
If the rings have A on half of them andB on the others then A on firest grove and B in the second (letters up)
Chrome top.
Note...chrome is good for a dirty environment but hard on cylinder walls.
Respectfully
Chuck
  #8
Old 10-07-2017, 08:45 AM
itsid's Avatar
top and second ring should be of different color; top is usually a lighter color...
BUT much more important than color is SHAPE!
the top ring has a rounded shape (the face that's against the cylinder wall is rounded that is )
the second ring is asymmetrical; the lower edge is ever so slightly wider than the upper.
(it has distinct sharp corners though compared to the top ring!)
both (top and second) should have a marking on the top.
likely A (top) and B (second) sometimes A is just marked with a T though indicating the top ring
(as it's symmetrical it shouldn't matter which way around it's installed other than for good practice)
the oil rings are AFAIK identical to one another and it makes no difference as to which one is the upper and which is the lower
and IIRC it doesn't even matter in which orientation they're installed.
  #9
Old 11-05-2017, 05:00 PM
Junior Member
I got the top ring, chrome with letter T facing up. and 2nd is darker with the T facing up? I didn't see any bevel of any sort on either top or bottom ring seemed pretty squared on all ends.is this correct?
  #10
Old 11-05-2017, 07:49 PM
SPP_MN
That’s how I would of done it.
Closed Thread
