Closed Thread
Old 10-01-2017, 11:11 AM
cheetahgod cheetahgod is offline
Default Need help new to go karts
Hi I bought an old manco go kart for $50 with a 212cc preadator engine. I need help fixing/finding some wheels. The bearings are shot and the back non-drive wheel didn't have a bearing inside the wheel.
Thanks
Old 10-02-2017, 12:05 AM
OzFab's Avatar
OzFab OzFab is offline
You did well on the purchase price, unfortunately, you now have to spend money on decent wheels, those are rubbish; the only half decent one is the drive wheel & that's not great...
There are many parts suppliers, one of our favourites is Go Power Sports...
Old 10-02-2017, 01:32 AM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
Flat-free solid tires on the front. I had to do a second take because they look like low-profile tires. How well do those work?
I'm not even sure if any of the wheels are what actually came on the kart, but replacement wheel bearings are cheap and a dime a dozen.
GoPowerSports.com
MFG Supply.com
BMIkarts.com
Tons of vendors on that famous auction site...
Your front spindles are going to be 5/8", so a 5/8" ID bearing... The rear axle is....1"? Not certain.
Old 10-02-2017, 07:47 PM
would it be worth it to convert to a live axle by welding an axle on?
Old 10-03-2017, 12:23 AM
Dustin2017 Dustin2017 is offline
SPP_MN
First question are you keeping it? If so why not convert it and put disc brakes while your doing the axle.
Old 10-03-2017, 04:54 PM
I am keeping the kart but don't won't to spend a ton of money. The new axel will cost to much so I'll pass on that
  #7
Old 10-03-2017, 04:58 PM
mckutzy mckutzy is online now
How much were you expecting to pay to fix this?? Budget if you will...
  #8
Old 10-03-2017, 06:30 PM
Hellion's Avatar
He said he'd pass on the upgrade, McKutzy.
He'd have to at least cut off the axle nubs flush with the frame, add live axle bearing hangers, the bearings, a live axle and get live axle wheels/hubs.
Besides, a one-wheel drive kart is conceivably faster anyway; it's gonna turn sharper than a solid live axle and there's less rotational mass for the engine to contend with.
  #9
Old 10-03-2017, 07:05 PM
SPP_MN
Ya it'll turn one way good and the live axle kits Are fairly cheap.
  #10
Old 10-04-2017, 01:31 AM
I paid $50 for it and need new tires and rims which are going to be $100+.
Don't went to spend too much
  #11
Old 10-05-2017, 04:43 PM
The current drive wheel is a 15-6-6. I don't know how this wheel and rim sizing system works. Can somebody point me in the direction of wheels and tires that will fit?
Thanks
(dead axle)
  #12
Old 10-05-2017, 10:17 PM
T-man's Avatar
T-man T-man is offline
Ha hey cheetagod ... that size is the most common size for the front tires of lawn tractors.
http://www.ebay.com/itm/TWO-15X6-00-...lVS6qQ&vxp=mtr
But you'll have to get tubes for them also..
http://www.tmanskarts.com & 1 Primary youtube channel T-mans Go Karts
  #13
Old 10-06-2017, 12:08 AM
SPP_MN
Why you gotta run tubes on the riding mower tires for?
  #14
Old 10-06-2017, 07:20 AM
qtband's Avatar
qtband qtband is offline
Quote:
You don't. Only if you have split rims.
I asked God for a go-kart, but God doesn't work that way. So I stole one and asked for forgiveness.
  #15
Old 10-06-2017, 07:36 AM
T-man's Avatar
oh yeah , true . some times you do. I have some that dont have split rims and they have tubes in them. I was just referencing what I have.
The reason behind using a tube is if the bead doesnt seal between the tire and rim to hold air.
  #16
Old 10-06-2017, 08:51 AM
SPP_MN
I was gonna say you don't normally run tubes in Tube less tires. Make sure you put fall or winter air in your new tires for better traction .
  #17
Old 10-06-2017, 01:09 PM
"Fall or Winter air"...... Care to elaborate on this subject?????
Is that kinda like blinker fluid or greasable muffler bearings???...
  #18
Old 10-06-2017, 01:45 PM
SPP_MN
It's Exactly same but different . Lol
  #19
Old 10-06-2017, 06:14 PM
I'm looking for new tires and rims for both the front and back. Can someone please suggest some tires that can be bought from go power sports or somewhere simmilar?
  #20
Old 10-06-2017, 06:32 PM
Hellion's Avatar
Quote:
You need totally new on the front (rims and tires, bearings)
But your rear wheels and tires look FINE. Even the 15" tires still have the whiskers on them. And they're Carlisle brand = Very Good.
1. Are you looking for OEM style rims and tires for the front and back in any event?
2. Which Manco kart is this? Does it have a model # decal on it?
2A. Looks like a model 415. http://kartingdistributors.com/pdfs/...l_20050223.pdf
You have a confusing array of photos. From the above manual, the front AND rear wheel bearings appear to be Part #5090 Bearing, ID 5/8" x 1-3/8" OD Snap Ring.
Last edited by Hellion; 10-06-2017 at 06:45 PM. Reason: Answering my own question.
Closed Thread
