Old 11-07-2017, 02:35 PM
Tpdingo Tpdingo is offline
Default Is predator 212 a direct swap on Dingo 286
Pretty much what the title says. I got the Dingo for 50$ but the engine is dead as a doornail and missing parts. I know the yerf-dogs have that issue where the engine shaft is 3/4" longer than the predators and it fits by a less than a centimeter.
Old 11-07-2017, 02:38 PM
ezcome-ezgo's Avatar
Should be pretty close to direct. Came with a 5-6hp B&S engine and a 30 series TC.
Old 11-07-2017, 07:57 PM
Hellion's Avatar
Hellion Hellion is offline
Disc brakes'r for cowards
It should be a direct fit as far as the "footprint" or the mounting base dimensions go, and having the bolt holes line up. No issue there on my 286...
However, the newer engines have more horizontal mass than the older engines--they have more girth with the top mounted gas tanks that can interfere with the frame sometimes...
Sometimes the cylinder canted over to 45° or whatever angle it's at interferes with fitment at the rear of the kart frame as well.
Old 11-08-2017, 09:55 AM
Than that settles it, on to Harbor Freight to get a HEMI 212 because my local store has alot of them.
Old 11-08-2017, 10:11 AM
Don't forget your coupon.
Old 11-08-2017, 06:26 PM
Default Paint color of Manco Dingo purple.
The paint job on my Dingo 286 purple is quite good but some areas like under the seat and by the pedals are rusted. What color spray paint could I use to repaint those areas after sanding that would match?
Old 11-08-2017, 07:40 PM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
Purple?
The Following User Says Thank You to Whitetrashrocker For This Useful Post:
kevbo22 (11-08-2017)
Old 11-08-2017, 07:51 PM
Default Yea its purple.
Originally Posted by Whitetrashrocker View Post
Purple?
Purple.
Old 11-08-2017, 08:04 PM
kevbo22's Avatar
kevbo22 kevbo22 is offline
Purple?
Old 11-08-2017, 08:07 PM
Dustin2017 Dustin2017 is offline
SPP_MN
Anything but purple.
  #11
Old 11-08-2017, 08:23 PM
Let me rephrase that.
Purple.
  #12
Old 11-08-2017, 08:42 PM
Texan's Avatar
Texan Texan is offline
Senor Member
Purple
  #13
Old 11-08-2017, 09:12 PM
MTNSleder MTNSleder is offline
Banned
How bow Purple..?
  #14
Old 11-09-2017, 03:33 AM
itsid's Avatar
itsid itsid is online now
that pic doesn't show up (at lest not in my part of the town)
Anyways.. IIRC
Rust-OleumŽ Painter’s Touch Ultra Cover, Gloss Purple (or was it "grape" ??)
should be fairly close to the original Manco color *shrugs*
BUT why not take a small purple part with you and color match it to the color cards
on the shelf (or have it mixed for you?)
  #15
Old 11-09-2017, 04:31 AM
Sorry if this didn't come out clear, but which purple is it. Is there a spray paint brand that matches the color very closely. I know I want to paint it purple .
  #16
Old 11-09-2017, 07:17 AM
Old paint on your frame and new paint you put on will not be an exact match even if you got the exact paint the factory used. Time, oxegenation, and UV have taken there toll.
Like Sid said take a purple part with you to the store and hold it up to the spray can lids. Or have a body/paint shop mix you some.
Unlike a vehicle there is no paint code we can look up.
Happy hunting.
  #17
Old 11-09-2017, 08:24 AM
Black is the new purple.
  #18
Old 11-09-2017, 11:10 AM
Eh.
Possibly blue, maybe green. Not yellow, orange or red. Black is just a boring color.
  #19
Old 11-09-2017, 10:20 PM
Hellion's Avatar
This is an entertaining thread. I heard there might be pics but see none.
My vote is for ultraviolet.
If matching paint is crucial, you can always take a sample of your existing paint to a place like Sherwin Williams Automotive Finishes and they can color match it in a pint or a quart....even put it in an aerosol can for you.
The Following User Says Thank You to Hellion For This Useful Post:
obone (11-10-2017)
  #20
Old 11-09-2017, 10:32 PM
SPP_MN
Just repaint the whole kart purple and be done with it.how hard is that????
