Closed Thread
  #81
Old 03-12-2011, 12:26 PM
r_chez_08's Avatar
r_chez_08 r_chez_08 is offline
Should be in the shop...
make sure its a similar i/d. a honda gx120 or a small pitbike carb might work.
as for the sparkplug, could you tap it a larger diameter, then drill and tap some threaded bar for the spark plug to go into?
My process of thought:
Anyone can drive a fast car, few can drive a car fast.
  #82
Old 03-19-2011, 09:50 AM
j.concepcion54321's Avatar
j.concepcion54321 j.concepcion54321 is offline
Rebuilding KTM, Need Kart
Quote:
Originally Posted by Bluethunder3320 View Post
IMO, if you arent going to do a full restoration (sandblast parts, nice and clean), not worth fixing.
Im starting to agree with blue and i think im gonna postpone this project until i can get money to do a full restoration and get new parts and make it nice, etc. id rather wait and make something nice that works good then get something to kinda work taking all the shortcuts.
  #83
Old 03-19-2011, 10:33 AM
Gillgamesh64 Gillgamesh64 is offline
First thing i woud do would be pull the carby off and drop it into a tub full of deisel or kerosene or similar than out with the spark plug and check compression i would squirt a little wd40 in the barrel to help lube it up a bit than test compresson dont put oil down there as it will mess wth the compression reading, once you get a reading you can make your mind up wether it needs a full rebuild or if it is worth the hassle, Than i would test the spark if there is no spark go through the process of elimination untill you have spark, once you have that sorted go back to the carby and after a few days in the wash hopefully will be free and all parts movable, than inspect carby remove bowl and slide and clean it unclog holes and make sure the float works...... But yeah if its screwed well i guess its screwed i am sure you will find a carby of a simular engine or a newer kohler?
  #84
Old 03-19-2011, 10:41 AM
Sorry i am a bit late on this after reading the thread propery i must say just get rid of it, I meen if you are not realy into the vintage part why bother, I meen if you want the original engine buy one working later it will probably cost you less any way....
  #85
Old 03-19-2011, 11:06 AM
yeah thats what i figured. thanks for the post ill still keep working on this engine as its the only one i have but i wont do a full rebuild buying brand new parts or anything for the time being.
Gillgamesh64 how can i check for good compression??
  #86
Old 03-19-2011, 11:16 AM
you do the test when the engine is intact and a compression tester is a gauge you push or screw into the spark plug hole than turn the motor over, it just messures how mutch pessure build up inside the engine... The more the better, if compression is bad it means the rings are worn allowing air to slip past tham, you can get a cheep tester for about thirty bucks but if you ask every one you know someone is bound to have one they could loan to you.
The Following User Says Thank You to Gillgamesh64 For This Useful Post:
j.concepcion54321 (03-20-2011)
  #87
Old 03-20-2011, 03:33 PM
thanks, but i dont have 30 bucks or any friend that are into this kinda stuff
  #88
Old 03-20-2011, 04:26 PM
r_chez_08's Avatar
Just saw this araldite putty stuff today and it said fixes stripped threads. I dunno if it would hold the heat and compression, but wortha try?
Rob
  #89
Old 03-20-2011, 05:26 PM
i figured id just buy another head instead of taking the cheap way out. (im gonna have to get one in the long run) right now im trying to get some cash so that i can keep working on the motor. i know this is kindof offf topic but it just came to my mind. would this engine be able to power an offroad go kart with some decent torque and speed? and how do you hook up old car wheels to a live axle? like the old donut style tires?
  #90
Old 03-29-2011, 06:04 PM
does anyone know what size shaft this is??
on youtube i saw a vid of someone who put a chainsaw carb on a 5 horse briggs and it ran strong and revved higher. i have an old weed eater thats all taken apart. what are the odds that it'll work??
  #91
Old 03-29-2011, 06:08 PM
fowler's Avatar
fowler fowler is offline
that sould have the opposite affect
the engine would run too lean if at all
EDIT
wait unless it was a chain saw of similar cc then it might work
That's not an oil leak
It's horsepower sweat
  #92
Old 03-29-2011, 07:28 PM
well the weedeater is 21cc and the engine is maybe 100+cc so what do you mean by running lean??
  #93
Old 03-29-2011, 08:45 PM
Bluethunder3320's Avatar
Bluethunder3320 Bluethunder3320 is offline
Thats weird, i wouldnt think it would work.
Anyways, i tell you that its not worth fixing unless you make it nice, because i was restoring a tecumseh built from the 1950-1970 time period, i washed all the parts, worked hard, then slapped on some high temp rattle can paint and called it GOOD. it lokked amazing. After a week, the paint was totally dry, and it looked bad. I rushed the final stuff. Now i dont like it.
Im thinking seriously about getting this to sandblast the paint off and make it factory again.
http://www.harborfreight.com/abrasiv...net-42202.html
I got the engine last fall and still havent heard it run yet! It will be a while too. But take your time, get it spotless, and it will be rewarding, like you got a brand new kohler 4hp as it came off the production line many many years ago.
Good luck.
  #94
Old 03-30-2011, 10:59 AM
Thanks blue. im gonna put this engine in a box and throw it in the shed. ill try to get it running again over the summer and ill start a new thread. my main focus now is my 5 horse briggs so ill spend more time onn that.
Closed Thread
