Closed Thread
Old 07-15-2019, 04:47 AM
KOUP KOUP is offline
Junior Member
Default Sprocket Help Please !
Hi All,
I have a buggy that I'm going to use a 390 clone engine with a torque
converter . The torque converter has a 10t 420 sprocket and my rear wheel diameter is 18". Could someone advise on the best rear sprocket size for being practical and reliable please ?
Any help greatly appreciated.
Old 07-15-2019, 04:51 AM
You need to provide torque converter information. Specifically the driven size (6”, 7”, 7.5”, 8.5”) if this is on a live axle and you want a steel sprocket, the only “off the shelf” option will be a 60 tooth. Bigger than that will require a bigger investment and welding. Aluminum there are more options but on a buggy I am opposed to aluminum.
Old 07-15-2019, 07:01 AM
itsid's Avatar
itsid itsid is offline
Sorry Mrmonk but you are incorrect in every point
What he needs to provide is a good estimation of the WEIGHT of the vehicle first.
knowing what exact tc we're dealing with surely helps though.. but if we assume a 40/40D
as per usual for a gx390 engine, a 40/44D would work as well in the end.. so it's no critical info at all!)
Also: 420 sprockets (aka #41 sprockets since they're exact the same in profile)
are available up to 80 teeth off the shelf and up to 124 teeth (20" in diameter) on a custom order from Azusa
And aluminium sprockets are perfectly fine for a gx390 clone engine
it's the engine torque that could destroy the sprocket, not the vehicle!
And with a rubber belt in between, the bottle neck will be belt slip anyways
Old 07-15-2019, 08:46 AM
Junior Member
Hi, thanks for quick reply.
Think I may be kicking myself here, just thought torque converter would be ideal as it had a 1" bore but would really appreciate whether you think I could get away with using it due to 8hp rating if using the correct rear sprocket size please as I believe it is a 30 series. Buggy is old honda pacer sort of size 10t 420 drive sprocket ,solid rear axle. Thanks in advance.
Old 07-15-2019, 09:22 AM
420Racer 420Racer is offline
Rip It Up
So do you have the engine and torque converter already?
Old 07-15-2019, 10:04 AM
mckutzy mckutzy is offline
Lets see some pics...
  #7
Old 07-15-2019, 11:06 AM
itsid's Avatar
A series 30 (TAV2 Kit usually sold as a cheap chnese copy complete kit on ebay)
is not going to serve you very well if at all.
the belt for a series 30 is smaller than for a series 40
(no they're not interchangeable between series)
and the small belt just cannot transmit enough engine torque for you reliably.
A series 40 (also sold as a chinese well made copy 'semi' kit for relatively cheap on ebay [both pulleys sometimes with a belt sometimes w/o]) is what you need to pick for an engine like yours
All you need to complete is a jackshaft kit
and a belt that matches your center to center distance.
Stay clear of the sets that come with a backplate!
They do not serve you well in the end.
  #8
Old 07-15-2019, 11:19 AM
bthompson224's Avatar
bthompson224 bthompson224 is offline
I'm curious, why?
  #9
Old 07-15-2019, 11:55 AM
itsid's Avatar
Quote:
Originally Posted by bthompson224 View Post
I'm curious, why?
series 30 kits are not suited for the engine as mentioned.
and the series 40 kits are a bad idea in the first place;
there is very good reason why Comet never made a backplate for the series 40 TC.. it's a stupid!
First ideally you want the series 40 running inboard not outboard (as a series 30 runs)
that way the moveable sheaves of driver and driven run in unison and belt alignment is always as set in rest.
Running the driven outboard (as needed on the backplate) would require the driven to float ~7/8" inboard to compensate for belt offset during shifting phases.
that is simply IMPOSSIBLE and thus the belt runs crooked either in low or in high gear (or in both)
With an outboard driven and outboard clutch.
dramatically reducing belt life in the process stealing another significant portion of your power.
So while I generally like GPS.. that is a brain fart
(one GTC had before them but they scrapped the idea before they ever sold a set... they even removed the announcement of it's developement from their website)
NOW a few months ago (to my best knowledge) there's this kit on ebay showing up with an inboard running clutch ...
and while that could solve the belt alignment issue for some,
it requires a looong engine shaft that is nowhere to be seen on current industrial engines ..
I haven't seen one installed so far, and I haven't heard any reports on that being a viable alternative so far.
Chances are you need to fab your own shaft extension (keyed 1" shaft ~1.5" long center drilled and properly keyed to the existing PTO)
and then hope for the best the keys don't move..
IDK but IYAM that's way more trouble than installing a proper Jackshaft plate or two pillow blocks.
Sure, you can install that stupid backplate thing, and run your 13horse engine with only 8horses at the wheels.. but WHY?!
especially since it'll cost you not only a rather expensive back plate but also a rather expensive belt every other month that you wouldn't need without that idiotic contraption.
Or short: laziness comes at a high price (in hard earned dollars this time)
PS and until I've seen a inboard running clutch working reliably without any additional fabwork.... I remain with
"Comet would have made one if it'd work as it should" so it doesn't work too well either.
  #10
Old 07-15-2019, 11:58 AM
Thanks. Would you say the same thing about a series 30 on a smallblock?
  #11
Old 07-15-2019, 12:33 PM
The torque converter selection plays a huge role in speed and torque. Weight is important for gearing choice...but so is gearing and we both know the driven influences the gearing and top speed. We have been discussing this in other threads. If off the shelf 1Ē bore sprockets are available that do not require an additional hub and are made in steel please tell me where...I have looked extensively. Even sprockets that work with a hub I canít find in steel higher than 60t. They are either aluminum or are for #35 chain.
Speaking of chain the #41 is weaker than the #40. This is important especially for a buggy.
He is building a buggy, which would lead you to believe it is an off-road build. Sure aluminum will work but for how long? Dirt and other particulate will get on the sprocket between the chain and it will wear considerably faster than steel, and if it is not perfectly aligned again it will rear much more rapidly.
Iím far from an expert so take my info with a grain of salt.
  #12
Old 07-15-2019, 03:27 PM
itsid's Avatar
Quote:
True but he's talking about 420, not #41
And while 420 has the exact smae outer dimensions as #41 it's stronger than #40 (by ALOT!)
most of the magic is pin diameter btw..
The TC plays 100% NO ROLE in torque nor speed..
in fact you can have more of either without one
(about 20% more at least)
A TC just is the best compromise we can make if we want both torque AND speed;
But a TC is no magic spell it toohas to rely on correct gearing.
And that gearing decides if you have enough torque and/or enough speed.
And again: if we dial in for the smaller of the two options (a 7.5" driven on a series 40)
we are still gearing great for the larger 8.5" driven
producing less top speed at worst..
but as you know.. getting a smaller sprocket than anticipated is always the easier task, than the other wy around
Your wish for steel is bs.. but if you so please just look for industrial sprockets rather than hobbyist ones and you'll find plenty.
grainger for example..
usarollerchain has some Btype (hub section) in 80 and 112 T for all I know on their shelves as well...
A B type 112 T is ~18" in diameter that afixed by nothing but the B-type hub is -mildly said- a 'brave' idea
That only really works on static appliances, certainly not on karts..
You want a RIGID base (hence karting hubs are usually large in diameter themselves for bigger sprockets... to prevent lateral play and jumping chains)
especially for off roading (buggy, huh?)
The Following 2 Users Say Thank You to itsid For This Useful Post:
950speed (07-15-2019), Mrmonk7663 (07-15-2019)
  #13
Old 07-15-2019, 03:52 PM
950speed's Avatar
950speed 950speed is offline
Thanks sid that helps a lot for he future on other projects
  #14
Old 07-15-2019, 07:00 PM
itsid's Avatar
Oh.. I was mistaking.. it's not grainger;
it was Linngear that had the vast selection of sprockets
(#40 steel 120 teeth 19" 23lbs.. have fun )
  #15
Old 07-15-2019, 07:11 PM
Through my lack of knowledge we have received an education . Thanks for the detailed response sid
Closed Thread
