Closed Thread
Old 07-09-2019, 06:18 PM
mrdeadman1 mrdeadman1 is offline
Default Hex axle
Can I use a sprocket and hubs that have a 1in round hole on this by using a set screw? can find the parts I need for the hex locally.
Old 07-09-2019, 06:21 PM
mckutzy mckutzy is online now
Ideally, no... They will just loosen and gouge the heck out of the axle, and rattle around... or similarly, break off the setscrew as it will be a length down to make contact with the flat...
Old 07-09-2019, 07:06 PM
ok even if I put a piece of keystock in the keyway on the hubs?
Old 07-09-2019, 07:07 PM
bthompson224's Avatar
bthompson224 bthompson224 is offline
Get the right parts.
Old 07-09-2019, 07:15 PM
by all means I understand the correct parts are a better option but short of replacing the whole axle with a 1in, I cannot source the parts locally
Old 07-09-2019, 07:17 PM
Not experienced with the hex axle, but I see too many people struggling with parts for them. In the long run it might be worth it to put in a new axle.
The Following User Says Thank You to bthompson224 For This Useful Post:
mckutzy (07-09-2019)
  #7
Old 07-09-2019, 07:24 PM
You can get a piece of cold finish 1" and go from there... that will get you started...
Youll have to cut some keyways in for brake and sprocket, with a Dremel moto tool... Its doable but slow...
Or get a piece of 1" keyed shafting...
  #8
Old 07-09-2019, 07:44 PM
Randy H Randy H is offline
mrdeadman1,
A couple questions, how long do you need it and what condition/length is your hex axle?
This axle is 39“, from BMIKARTS.COM. Off A Yerf Dog, I think.
If your interested maybe we can deal. This is a little rusty from sitting in the garage, but otherwise unused.
  #9
Old 07-09-2019, 07:50 PM
That'll polish out no prob...
The Following User Says Thank You to mckutzy For This Useful Post:
Randy H (07-09-2019)
  #10
Old 07-09-2019, 08:12 PM
Quote:
I agree. I should have given it a coating of Prep and Etch (phosphoric acid)and oiled it up. I will do that tomorrow
  #11
Old 07-09-2019, 08:55 PM
Guapo613 Guapo613 is offline
Quote:
Go Powersports has Manco hex axle parts
  #12
Old 07-09-2019, 09:03 PM
Randy H its 42 in I believe but 39 will work, what state do you reside in I'm in Kansas
  #13
Old 07-09-2019, 09:06 PM
I'm in West Michigan.
  #14
Old 07-09-2019, 09:08 PM
420Racer 420Racer is offline
Rip It Up
Why don't you just get the hub and sprocket for the hex axle and use the axle you have. Most of us can't just find parts locally that would be great tho lol
  #15
Old 07-09-2019, 09:13 PM
the hubs for the wheels are not available, just 6in wheels with integrated hubs, I have 8in wheels that I want to use so was looking for options
---------- Post added at 10:13 PM ---------- Previous post was at 10:12 PM ----------
Randy H how would you suggest doing this?
  #16
Old 07-09-2019, 09:35 PM
BMI indicates these are in stock.
https://www.bmikarts.com/4-x-4-Wheel...re_p_1655.html
I'll ship to you and you ship to me. I'll check out shipping tomorrow, if you want.
Just noticed they are for 1".
  #17
Old 07-09-2019, 09:36 PM
Rip It Up
I have these I'd sell them for cheap if that helps. They are 8 inch wheels for a hex axle and 18" holeshot tires. Either way to do it right your gonna have to spend a few bucks. I have some other hex parts too feel free to pm me. The hex stuff works fine but I always grease the wheel hubs before installing them. Otherwise just convert to the 1" if you want your kart to work
  #18
Old 07-09-2019, 09:42 PM
Rip It Up
I'm confused why would he need a new axle if he can get those hubs? Those hubs will fit his axle if the wheels he has use a 4x4 bolt pattern
  #19
Old 07-09-2019, 09:46 PM
Quote:
⅞ vs. 1“. Maybe I'm missing something IDK
  #20
Old 07-09-2019, 09:56 PM
Rip It Up
⅞ vs. 1. Maybe I'm missing something IDK
There's only one hex axle for karts and it's a 7/8 but it is 1" from point to point.
---------- Post added at 11:56 PM ---------- Previous post was at 11:53 PM ----------
Either he gets the right sprocket hub and wheel hubs or just converts to a 1" axle
The Following User Says Thank You to 420Racer For This Useful Post:
Closed Thread
