Go Back   DIY Go Kart Forum > Build Contest > Build Off Contest Build Logs
Closed Thread
  #161
Old 04-07-2019, 07:50 AM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Hook up two wires to the choke lever, one going up, one going down. Hook them up to two levers where desired.
Currently Flathead-Crazed
  #162
Old 04-07-2019, 09:51 AM
pa17315 pa17315 is offline
Quote:
One look at my current hook up, I have wires, levers all over places. two more wires for the same choke would send me to the nut house. Beside, I am still in the looking stage. There are distraction stage and then build stage. I have time.
  #163
Old 04-07-2019, 11:01 AM
Electrical Bird's Nest Special.
  #164
Old 04-11-2019, 09:23 AM
Default 2019-Predator Engine Remote Choke part 2
Parts ordered from Ebay in preparation for Predator 420cc choke relocation:
Carburetor Carb Fits PREDATOR 346CC 11HP 420CC 14HP OHV ENGINE GO KART CART
(Just incase I mess up the carburetor)
Push Pull Choke Cable 96" fits Oregon Conduit Go Kart Throttle Cable 60-122 Best
  #165
Old 04-20-2019, 09:06 AM
Default 2019-Predator Engine Remote Choke part 3
I have decided to make a new lever where I can incorporate the choke cable for remote choke.
New parts need to be made out of scrap pile.
Initial layout and testing for new choke lever
  #166
Old 04-20-2019, 09:10 AM
Default 2019-Predator Engine Remote Choke part 4
Top plate in place of existing choke lever arm
  #167
Old 04-20-2019, 09:12 AM
Default 2019-Predator Engine Remote Choke part 5
Welding a pin to carburetor choke shaft
  #168
Old 04-20-2019, 09:21 AM
Default 2019-Predator Engine Remote Choke part 6
Modifying existing choke lever shaft.
On the existing choke lever shaft, I have filed the protruded lip so the part can move freely. Pic will be posted
  #169
Old 04-20-2019, 09:23 AM
Default 2019-Predator Engine Remote Choke part 7
Testing out new choke lever part
The Following User Says Thank You to pa17315 For This Useful Post:
ezcome-ezgo (04-24-2019)
  #170
Old 04-20-2019, 12:18 PM
My choke lever is broken....
Seems like you're pretty mechanically capable, if I were to make a similar part, it would be UGLY!
  #171
Old 04-20-2019, 08:19 PM
Jack of all trades, master of none!!!! I forgot to upload a pile of ugly discarded parts.....
  #172
Old 04-21-2019, 08:55 AM
Well, it's still prettier than I would make it...
  #173
Old 04-22-2019, 03:29 PM
Default 2019-Predator Engine Remote Choke part 8
I have made two different choke versions with varies heights for clearance. On the stock carburetor, it works perfectly.
Time to check on the aftermarket carburetor from Ebay.
  #174
Old 04-22-2019, 03:37 PM
Default 2019-Predator Engine Remote Choke part 9
New choke lever doesn't fit on the aftermarket carb.
The factory carb has screw in butterfly on the choke lever and the hole is larger.
Aftermarket carb has the butterfly pressed in and the hole is slightly smaller.
Spacing between choke lever are different also...
Back to drawing board.
  #175
Old 04-22-2019, 03:41 PM
Default 2019-Predator Engine Remote Choke part 10
Install choke cable on go kart and rigged up a support for choke cable sleeve.
  #176
Old 04-22-2019, 04:17 PM
Default 2019-Predator Engine Remote Choke part 11
Choke lever version #3
I have decided to cut 1/2 metal rod instead of using two 1/4 nuts like the previous two versions.
One minor change on this on. The main hole start out to be 5.5 mm drill bit, and then #6 drill bit is drill almost through except last 3/16" or 1/8 of an inch. This will keep the post from shifting on the carb.
It is not quite centered on the 1/2 rod.
landuse (04-23-2019)
  #177
Old 04-23-2019, 05:19 AM
LightningTeg's Avatar
LightningTeg LightningTeg is offline
Nice build, we are very similar.
I also was just considering a choke relocation or just running some kind of cable to the dash to control it. I was thinking just taking some filler rod and making a easy linkage. I dont want to put that much effort into it.
---------- Post added at 07:19 AM ---------- Previous post was at 07:16 AM ----------
Quote:
Originally Posted by pa17315 View Post
Item received.
There are 5/8 inch bushings which goes in the bearing to accommodate the 5/8" spindle. That may pose a problem because it may not stay in place. It moves freely and may not remain on the bearing.
I cut a 5/8" DOM pipe to fit in between the two bushings.
This is indeed a problem.. Seems silly to have bearings that can float around
I thought some flanged sleeved bearings would do the trick
  #178
Old 04-23-2019, 08:46 AM
Default 2019-Predator Engine Remote Choke part 12
Choke lever version #3 completion.
Here are the working version. There are some issues that I would like to finalize.
In the next version, hopefully the last version, I want to install limiter on the remote choke lever control so you don't yank the choke lever rod out past acceptable point on the carb.
In order to connect choke cable to the carburetor, I need to make a guide to keep the cable straight from twisting when you pull the choke up front of the go-kart.
The guide is the orange 1/4 rod bend at the end and a piece of cable sleeve is welded to it. At the other end of the rod, I ran 1/4 x 20 die to about 2 inches.
This guide is adjustable and keeps the cable in its path. I can turn the guide down to keep clear from the gas throttle.
The spring on the choke lever hooks on the carburetor is an extra fail safe measure just incase the choke cable fails.
Is the spring necessary? I am not quite sure but it does sound good when you factor in the push and pull capacities for the choke cable is 10 lbs. and 25 lbs. respectively.
landuse (04-24-2019)
  #179
Old 04-24-2019, 10:37 AM
Default 2019-Predator Engine Remote Choke part 13
Choke pull stop.
Rigged up something simple to keep the choke pull from over travel which could damage the choke lever on the carburetor.
  #180
Old 04-24-2019, 10:50 AM
Default 2019-Predator Engine Remote Choke part 14
Remote choke cable for predator engine recap:
This is an interesting problem to tackle for predator engine. Same idea would work for the 212cc as well. I am sure go kart members would improve on what I have come up.
It would be nice to present a how-to on YouTube. I am illiterate when it comes to thing like that.
Finally, I am going to improve on it sometimes in the future. Maybe a metal plate which incorporate choke, and throttle cable hook-up.
Closed Thread
