Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 02-07-2018, 03:36 AM
Josh.hymel Josh.hymel is offline
Junior Member
Default Razor "boom" buggy
So my son was given a razor dune buggy with a set of bad batteries and a bad motor. After discovering the cost of replacing the motor/batteries I decided to modify the cart to run from a 79cc predator. Along with a new motor I was going to put 15inch meaty mud tires on the back and 10 inch tires on the front. Also had to adjust the steering which was way far forward to something a bit more natural.
I cleared the room needed and fabbed what was needed to mount the engine. I had to machine the 3/4 inch hubs to 22mm and make a 5mm key shaft for the rear. Turned new spindle sleeves for the front wheels. Because the kart is so small and I was trying to not cut and modify the frame I opted to stick with the #25 chain and stock jackshafts, so I had to weld a #25 sprocket to a 5/8 clutch.
All worked out well. Until my son got to ride it. Although I was able to get a 6.2:1 final drive ratio on the chain drives, the 15inch wheels meant for very little hill climbing torque. This is when I decided to build a 2 speed gearbox.
I made my go karts 2 speed gearbox using Lovejoy couplings and nesting sprocket hubs into the coupling. Essentially making a "dog" type of clutch system similar to how boats engage gear. The final gear ratio are 5.2:1 and 10.8:1.
Here's some pics
Kens kart https://imgur.com/gallery/HO927
The Following 3 Users Say Thank You to Josh.hymel For This Useful Post:
ezcome-ezgo (02-07-2018), mckutzy (02-07-2018), Whitetrashrocker (02-07-2018)
Old 02-07-2018, 04:51 AM
landuse's Avatar
landuse landuse is online now
Nice!!!! So how does she run now with the 2 speed gearbox? I would personally have just gone for a bigger engine, but that's me
Old 02-07-2018, 07:17 AM
ezcome-ezgo's Avatar
You've made my day Ken or Josh or whatever your name is. Thanks.
The Following 2 Users Say Thank You to ezcome-ezgo For This Useful Post:
Old 02-07-2018, 07:56 AM
mckutzy mckutzy is offline
F-ing rights... You made my day aswell...
Please post a few more pics of the trans... Or some views of the parts, shifter and coupler/sprockets...
You've kinda opened a giant can of worms here... Defiantly got people interested...
Nice job...
Old 02-07-2018, 10:47 AM
qtband's Avatar
qtband qtband is offline
If those are Harbor Freight wheels on the front, get rid of them now! Accident waiting to happen. And it will.
I asked God for a go-kart, but God doesn't work that way. So I stole one and asked for forgiveness.
Old 02-07-2018, 11:29 AM
Whitetrashrocker's Avatar
Whitetrashrocker Whitetrashrocker is offline
Somebody help this genius host his pics here.
This is what we need around here.
Great Job Josh(?)
Do you have anymore projects you've done?
Think for yourself, Question authority.
  #7
Old 02-07-2018, 05:21 PM
zogthegreat zogthegreat is offline
I just looked at your pics on the link that you provided. That is awesome work oh the gearbox that you did there!
Previous project - "The Beast" - Current project "Spawn of the Beast"
  #8
Old 02-07-2018, 06:52 PM
TT540 TT540 is offline
Newb
I almost started with that same platform but stopped because of the steering wheel awkwardness and the decent resell value of the original setup.
That gear change setup looks great. Would love to see a video.
  #9
Old 02-07-2018, 06:54 PM
Junior Member
Sorry about the name confusion. My name is Josh. I am the father of a 5 year old (6 next month) named Ken.
I figure for the number of pics I was posting imgur would be best, if not please let me know a better way.
The front tires are intended to be replaced when the cart is actually operational.
I wish I knew how it drove with both gears. I have bench run it and it shifts smoothly. Unfortunately I have not finished due to weather and lots of overtime.
I did have an older nephew drive it while it was tied into 1st gear and it was quick, misbalanced and sketchy. haha
The steering needs some attention and when I rebuild the front it will add the weight I'm sure will balance it back out correctly.
Here is all the pics I have of the gearbox. I got carried away and forgot to take pics.
Kens gearbox parts
https://imgur.com/gallery/J1zqB
  #10
Old 02-07-2018, 06:59 PM
How to post pics.
http://www.diygokarts.com/vb/showthread.php?t=735
---------- Post added at 06:59 PM ---------- Previous post was at 06:59 PM ----------
This site will host them so we can all see them forever.
  #11
Old 02-07-2018, 08:12 PM
Junior Member
Here are hosted pics
  #12
Old 02-07-2018, 08:19 PM
Junior Member
Here's more
  #13
Old 02-07-2018, 08:23 PM
This is pretty frickin awesome...
Managed to look at all the pics at home on the comp... Very nice...
I see you even got idler bearings in the sprocket gears... I was wondering how you were going to avoid seizing...
  #14
Old 02-07-2018, 08:28 PM
Junior Member
And the gearbox.
I dont like how the pics aren't oriented correctly but any who... Here ya go
  #15
Old 02-07-2018, 10:01 PM
Fyi. The pics are sideways cause you took them that way.
No big deal. We just lay down to view them.
Closed Thread
