Old 01-24-2018, 02:29 PM
zogthegreat zogthegreat is offline
Default Comet 30 TC question - why do the belts shred?
Hi everyone!
So I'm planning a build this summer with my daughter and we are planning going to run a Comet 30 clone torque converter. I keep reading about how the clone torque converters keep on tearing up belts and I was wondering what the main reasons are and what can be done to prevent belt destruction?
Also, she wants to ride off road, (either a go kart or mini bike, she hasn't made up her mind YET! ), and my converter came with a red spring. Will this be OK for off road or should I order a different spring?
Thanks
zog
Previous project - "The Beast" - Current project "Spawn of the Beast"
Old 01-24-2018, 03:26 PM
anickode's Avatar
anickode anickode is online now
Originally Posted by zogthegreat View Post
Hi everyone!
Thanks
zog
Belts shred from misuse. Period. (Running damaged clutch components being the exception)
Improper alignment
Improper center to center distance and/or wrong belt length
Too much power (such as running a 1" 30 series on a predator 420 or a heavily modded 212
Too tall a gear ratio
The spring will depend on your drive ratio, wheel size, weight of the kart, etc, but a yellow spring will effectively keep it in a lower gear for longer, which is probably more desirable for off roading.
Unless "off roading" is blasting around a gravel /grass/dirt track where you will be running WOT a lot.
The Following 3 Users Say Thank You to anickode For This Useful Post:
2SlickNick (01-24-2018), Nosandwich (01-25-2018), zogthegreat (01-24-2018)
Old 01-24-2018, 05:34 PM
LOL, I keep trying to explain to her that skillful driving is better than a fast motor, but...
well she is 12, so....
(EDIT)
BTW, are all belts equal or are some better than others? I.e. Gator belts vs Chinese belts.
Old 01-24-2018, 06:25 PM
itsid's Avatar
itsid itsid is offline
the original Comet belts are most often the best belts you can get (even for the clones)
Some say the GTC belts are of good quality as well, but I heard a complaint about those once or twice as well..
chinese belts are hit and miss... some are perfectly fine and hold for hundreds of hours, some crap out after a few miles.. *shrugs*
Sure thing however: it must be a series30 TC belt of correct length for sure, no generic v-belt will do the job properly.
Old 01-24-2018, 06:27 PM
Do you have any links for original Comet 30 belts? I want to buy some spares before I go back to Canada in May.
Old 01-24-2018, 06:35 PM
itsid's Avatar
these seem to be the real deal:
https://www.gokartsupply.com/tcbelts.htm
or some ebay sellers..
https://www.ebay.com/itm/Manco-Dingo...-/122196569263
Old 01-24-2018, 06:42 PM
OUCH!
I only paid $57.00 for the torque converter!
Still, it will probably be cheaper to buy one than 4 or 5 cheap belts.
Old 01-24-2018, 11:00 PM
landuse's Avatar
landuse landuse is offline
Don't cheap out on belts!! You will regret it
Old 01-25-2018, 12:32 AM
Nosandwich's Avatar
Nosandwich Nosandwich is offline
The REAL Poboy
Yeah, you don't want your pants falling down.... JK.
I do not recall Congressman.
The Following User Says Thank You to Nosandwich For This Useful Post:
ezcome-ezgo (01-25-2018)
Old 01-25-2018, 09:08 AM
KartFab's Avatar
KartFab KartFab is offline
OUCH!
hey, at least you didnt pay $200 for the real deal https://www.gokartsupply.com/tavapp.htm
  #11
Old 01-25-2018, 07:55 PM
anickode's Avatar
Probably feel better about buying $30 belts for it though.
At least it's not as bad as printer ink. Cheaper to buy a new printer half the time.
The Following User Says Thank You to anickode For This Useful Post:
bob58o (01-25-2018)
  #12
Old 01-25-2018, 10:07 PM
Joe-405's Avatar
Joe-405 Joe-405 is offline
2018 Buildoff Winner ! 😎😎
I have had my barstool racer built for a few years now with the 30 series clone full setup and have never changed a belt. And it makes 11+hp and will run 50+mph
Edit : So yeah correct gearing to match the vehicle weight plays a bigger part of that shredding equation I think personally. Get the gearing right and your over half the way there.
  #13
Old 01-25-2018, 10:51 PM
landuse's Avatar
I have done this several times!!! The cost of a new printer (including ink) is cheaper than replacing the ink cartridge. No wonder people dispose of electronics so easily
Joe-405 (01-26-2018)
  #14
Old 01-26-2018, 07:09 AM
(chuckle), I don't like my printer, so I'm waiting for it to run out of ink so that I can get a different one!
  #15
Old 01-26-2018, 10:49 AM
KartFab's Avatar
I read somewhere that HP had about 50% of its profits from ink cartridges. They sell their ink printers super cheap, and sell their ink cartridges super expensive. I switched to laser last year and am pretty happy with the printer.
  #16
Old 01-26-2018, 10:52 AM
ezcome-ezgo's Avatar
Drinks are to Mcdonalds as Ink Cartridges are to HP. Bob, write this in an equation.
  #17
Old 01-26-2018, 11:15 AM
Improper alignment
Too tall a gear ratio.
How does the belt become improperly aligned? I'm playing with my converter right now and I don't see any way to adjust the alignment.
  #18
Old 01-26-2018, 01:25 PM
anickode's Avatar
It usually happens during setup when you put the shim washers on the shafts behind the pulleys. A lot of times they don't come with enough, and people don't bother to buy more. Different engines have different shaft lengths, different offset for the mounting face, etc, so there is no set number of washers to be used.
Or if the backplate gets bent, something comes loose, etc.
  #19
Old 01-26-2018, 02:58 PM
KartFab's Avatar
to check alignment you just take a straight edge, like a ruler, and you run it against the backplate of the drive and driven units they should be pretty close to lined up
The Following User Says Thank You to KartFab For This Useful Post:
anickode (01-26-2018)
