  #21
Old 02-11-2019, 03:58 PM
Mavaholic Mavaholic is offline
Made a battery box and hold down for a larger battery. Extended the oil cooler lines to mount the cooler up where it will get some air. Mounted the Honda tach, not only for the tach reading, but it has indicator lights. Red for oil pressure, green for neutral, amber for side stand, and blue for high beams. I wired it so it will only start in neutral. I wired the blue light to the lights so I'll know when the lights are on. The amber is not used at this time. I may find a need for it one day.
The Following User Says Thank You to Mavaholic For This Useful Post:
Panhead5496 (02-11-2019)
  #22
Old 02-11-2019, 09:53 PM
Panhead5496's Avatar
Panhead5496 Panhead5496 is offline
I can't wait to see this bad boy...it's going to rip.
  #23
Old 02-20-2019, 02:45 PM
Finished up the exhaust today reusing the stock mufflers. Tomorrow will work on the jackshaft. Should be moving on its own by the end of the day.
The Following 2 Users Say Thank You to Mavaholic For This Useful Post:
ezcome-ezgo (02-21-2019), Panhead5496 (02-20-2019)
  #24
Old 02-20-2019, 05:29 PM
Dang man that looks so BA!!!
It's going to be an animal when you get it running lol.
  #25
Old 02-20-2019, 07:14 PM
Kartorbust's Avatar
This is looking really good. Only wish they came like this from the start. Cannot wait to hear your results.
  #26
Old 02-20-2019, 10:40 PM
landuse's Avatar
landuse landuse is offline
Looking good!!!!!!
  #27
Old 02-21-2019, 07:38 PM
Got the new improved jackshaft installed. The first time around I used 3/4" with just the end bearings. First easy take off bent that. Live and Learn. Second time around I used 1" and added a third bearing support. Worked great. I could not come up with a way to make it adjustable for chain stretch so I'll just have to address that issue when it comes up. Problem is two different chains at 2 different angles. Still have a little tweaking to do and engine still seems a little too lean.
Panhead5496 (02-22-2019)
  #28
Old 02-21-2019, 07:41 PM
Default It lives!!!!
https://www.facebook.com/10000049341...type=3&theater
The Following 3 Users Say Thank You to Mavaholic For This Useful Post:
ezcome-ezgo (02-22-2019), Kartorbust (02-21-2019), Panhead5496 (02-22-2019)
  #29
Old 02-21-2019, 08:42 PM
Kartorbust's Avatar
That thing is stupid fast!
  #30
Old 02-21-2019, 11:15 PM
landuse's Avatar
Originally Posted by Mavaholic View Post
Nice!!! And look at the smile on your face
  #31
Old 02-22-2019, 02:29 PM
NICE! It sounds good too.
Now I wonder how it would be if you got some street tires and tried to make it road legal?? It would be so much fun running it on the back roads in the nice weather. Seeing as how you are in Florida, that would be most of the year
  #32
Old 02-22-2019, 04:16 PM
Joe-405's Avatar
Joe-405 Joe-405 is offline
2018 Buildoff Winner ! 😎😎
I can’t see the video for some reason what are you guys using ? I’m on my iPhone.
  #33
Old 02-22-2019, 04:45 PM
Kartorbust's Avatar
Android, Galaxy S7 Edge. Try singing off on Facebook. Might be security issues or something. It's a public video because I was able to watch it despite not having a FB account.
  #34
Old 02-22-2019, 07:51 PM
Joe-405's Avatar
I relinked it and got it to work............. now I need to sell my buildoff roller and transplant my 1200+cc efi ninja engine on one of those. Lol
  #35
Old 02-23-2019, 08:22 AM
Stephen115 Stephen115 is offline
Sick!!!!!!!!
  #36
Old 02-26-2019, 07:13 PM
Even though it ran, it ran like crap. One cylinder floods out and its running too lean in the lower rpm range. So its time to go through the carbs. Here, everything is cleaned up, hosed out, and ready for the kits to reassemble. I'm not sure how that Spyder got in there but he wasn't helping me any.
Panhead5496 (02-26-2019)
  #37
Old 02-27-2019, 12:33 PM
Joe-405's Avatar
I hate tuning those diaphragm style carburetors. Better you than me ! Good luck. I only had 2 and I finally gave up and ordered some knockoff flatslide carbs.
  #38
Old 03-08-2019, 05:03 AM
Carbs are back together and running great. Having shifter issues now. Need to rework my shifter.
  #39
Old 03-08-2019, 05:34 AM
MacGyvers Workshop MacGyvers Workshop is offline
MacGyver
Very nice work! Especially on the exhaust. Very clever!
  #40
Old 03-08-2019, 05:36 PM
Here is the problem with this shifter. Its basically a piece of flat stock with a bolt through it. The shifter had to move sideways to shift into F-N-R modes. The spring keeps side tension to keep the handle in the detents, which I cut out. All this side movement made for a lot of slop. I took this piece of 3/4" shaft and turned it into a bushing. If you can swing it, I highly recommend one of these cheap laths. With a little effort and a few mods, they are decent units. I've made many things over the years for my cars, bikes, and now go kart.
Joe-405 (03-08-2019), Panhead5496 (03-11-2019)
